Door ajar Light on........
Old Jun 24, 2009 | 06:34 PM
nissandoc's Avatar
nissandoc
Noticed it first thing this morning. Also the radio doesnt cut off when you open the door, any door. The key fobs dont work either. At first I figured the drivers door switch since its used the most. Replaced it but no change. The only code in the GEM was p1876 transfer 2wd (wtf?). Only had a short amount of time to mess with it, anyone ever have this problem?
Jim, can you fix my spelling on the title?
Old Jun 24, 2009 | 06:39 PM
12ozd's Avatar
12ozd
My first guess would have been the switch,but since you replaced it....
Bump to the top ,and a sub.
Old Jun 24, 2009 | 06:46 PM
zx250's Avatar
zx250
Of the next Riffraff East
Usually spraying the door switches will fix the ajar light, but the radio and fob thing sound GEM related.
Old Jun 24, 2009 | 07:00 PM
megawatt00's Avatar
megawatt00
All set.
I agree almost seem to be very close to the water in the GEM issue.
Has it been raining there Darrell?
Old Jun 24, 2009 | 07:48 PM
nissandoc's Avatar
nissandoc
No rain as of late. Had windsheild replaced about 2 yrs ago because it was sandblasted. Anyone with AE figure out how to monitor the GEM?
Old Jun 24, 2009 | 08:12 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Spray the latches with WD-40, and let it run down to the drain holes. Your radio works till you open the door. Spray and go.
Old Jun 24, 2009 | 08:16 PM
zx250's Avatar
zx250
But would that explain the key fob?
Old Jun 24, 2009 | 08:20 PM
nissandoc's Avatar
nissandoc
Rick, the radio does not cut off when the door is opened. I think I found the tab on AE to monitor the GEM but do you know if you can turn each item on/off with it?
Old Jun 24, 2009 | 08:43 PM
HKusp's Avatar
HKusp
2002's have a touchy GEM. I am betting that's what it is Darrel. Let us know what you find out with AE.
Old Jun 24, 2009 | 08:44 PM
megawatt00's Avatar
megawatt00
Iirc 99-01 gem 02-03 vsm
Old Jun 24, 2009 | 08:46 PM
HKusp's Avatar
HKusp
I thought it was '02's with the GEM issue. I know I have seen that more than once Jim, but you are probably right. I am more than likely perpetuating bad information.
Old Jun 24, 2009 | 08:58 PM
miller_feed
Did you try the WD-40??? If the switch is sticking, I would understand the radio would stay on.
Old Jun 24, 2009 | 10:45 PM
zx250's Avatar
zx250
I agree with Rick, spray ALL the latches good with WD-40 ang go from there. That may at least narrow down your problem.
Old Jun 24, 2009 | 10:56 PM
nissandoc's Avatar
nissandoc
If AE works like I think it should it'll tell me which door, but that dont explain why my fobs dont work.
Old Jun 24, 2009 | 11:48 PM
zx250's Avatar
zx250
Did everything start at the same time?
