throttle body grounds wire
Old Jun 29, 2009 | 08:15 AM
enriched&beyound's Avatar
enriched&beyound
Just curious....
Has anyone tried putting a ground wire from the Throttle body (fly-by wire units only), to the battery or other grounding bolt??
http://www.fordfusionclub.com/index.php?topic=76970.0
it has met with mixed reactions on the fusions, some say that the throttle response has improved. some say it has done little to nothing.
Just wondering if this has improved anything on the truck side??
Old Jun 29, 2009 | 11:33 AM
wildcard30's Avatar
wildcard30
Seen this mentioned on some of the Ford Focus boards. From my experience with my Focus (have not done it with my F-150) it makes no difference with either idle or throttle response.
The TB stepper motor is isolated from the TB. Therefore no reason to ground it. The stepper motor is grounded thru the wiring harness.
Here's the numbers I got doing the grounding (bonding) experiement with my Focus. Before bonding: No continuity between TB and any ground lugs. Running a 12 gauge wire from the TB to a ground lug, .05 ohms, measured from the TB to a point on the metal beside the ground lug. Change in response or idle: NONE
Some say you need #6 wire for it to be affective. If you have a very low ohms reading it would make no difference. You are just giving a return path for any voltage present (basically a voltage drain, like the twisted bare wire in most analog cable). A 16 gauge wire is capabile of carry 15 amps (based on 12 VDC). So why would you need anything larger? If you have amperage present on your TB, you have a serious problem. So if #8 or #6 wire is the "correct size" to feel the effect, why not use 00 wire? Wouldn't that be better?
IMHO, it's just another way to seperate you from your money. But the "seat of the pants", or butt dyno, can be a factor in stuff like this. You want there to be a difference, so therefore, there is a difference.
CrumpDogg
21
Feb 16, 2019 09:24 AM
Rusty_S
13
May 20, 2014 11:00 AM
Opiescheib
Jul 14, 2013 10:12 AM
dirtmonkey11
Jan 31, 2010 05:38 PM
OGNOM
Modular V10 (6.8l)
Mar 14, 2003 03:53 PM
