FPR question...
Old Jun 28, 2009 | 03:59 PM
Brown Falcon's Avatar
Brown Falcon
FPR question...
Ok, measured my fuel pressure stock and it was at 40 psi. Put in a BB and it bumped it to 65 psi.
No I read you want to be around 75 psi but not above 80 or 85.
Should I put another BB or shim in there to bump it up to 75? Or just leave it at 65 psi?
Old Jun 28, 2009 | 04:06 PM
250turbo's Avatar
250turbo
leave at 65, over 50 & under 80.
Old Jun 28, 2009 | 04:35 PM
Brown Falcon
Ok. THanks.
Old Jun 28, 2009 | 05:53 PM
Fullcrew7.3's Avatar
Fullcrew7.3
65 is great. Another BB would put you way over and put too much strain on your fuel pump.
Old Jun 28, 2009 | 07:35 PM
Brown Falcon
I think I've got all the little things done now... Just need a Paint Job, Chip, and a Limited Slip so I can get some traction!!!
I can't get on it hard turning corners or when it's wet even without a chip!!!
Old Jun 29, 2009 | 02:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
If you want to regulate your fuel pressure, you should use the screw and not the BB, like in this pic:
http://rides.webshots.com/photo/1076...39885334AzvuRS
I have read that a locker is way better than a Limited Slip.
Old Jun 29, 2009 | 03:32 PM
Brown Falcon
i'm planning on getting a locker... unless i can find a good limited slip from a Superduty at a junkyard
Old Jun 29, 2009 | 09:22 PM
Talyn's Avatar
Talyn
Shimmed mine tonight. Reads 70psi now. yay!
