hello fellas
Old Jun 28, 2009 | 11:24 AM
SoupCan™'s Avatar
SoupCan™
hello fellas
i guys..have been ghosting this forum forever, drooling over all your rigs...finaly with a new job, and people unloading thier toys due to the economic times...i have made 2 purchases hopeing to build them into one truck...
i have only a couple pics right now, my camera is dead..but i purchased a 78 f150, 351m,c6..dana 44 front 9 inch rear, short box..the truck is solid, PO lost interest..has a new front clip including bumper..motor is tired and smokes..but it came with anouther motor trans n transfer case thats low miles..my second purchase was a 77 f250 with a 460,c6 and divorced transfer case, closed knuckle d44 front d60 rear..motors fresh rebuild he made 2 passes at a local mud pit with 44 in boggers before blowing the front end...i dont have that truck home yet, its being delivered next week..i was wondering what it takes to convert my d44 to 8 lugg? a friend has a d70 rear i can get cheap...also, are the frames on these things the same? will the 460 frame mounts transfer between the trucks? i plan on puting the 460/divorced case combo in the 78....also the 78 has no mirrorors, and i hate the stock ones...any suggestions?
cheers
Rich
Old Jun 28, 2009 | 02:55 PM
bigdavesohc's Avatar
bigdavesohc
If you are planning to run 44s on a D44, don't waste your time, go for a d60 or stronger. As for the 8lug conversion, you probably just need an entire hub assembly from an f250.
Old Jun 28, 2009 | 04:12 PM
SoupCan™'s Avatar
SoupCan™
no im not going to run anything silly like 44s...prolly 35s or something similar
Old Jun 28, 2009 | 05:03 PM
SoupCan™'s Avatar
SoupCan™
here is the only pic i have so far
Old Jun 28, 2009 | 05:16 PM
F250army45d's Avatar
F250army45d
Nice looking rig welcom to the 73-79 truck world. Well if you want to convert the D44 to 8 lug what are the plans of the 9 inch rear? Or is this why you mentioned the D70 rear? Maybe take the F250 and use that body if its nicer the F150 has coil springs in the front leafs be easier to do bolt in mods.
Old Jun 28, 2009 | 05:40 PM
SoupCan™'s Avatar
SoupCan™
the body is whipped on the 77..i have kicked around putting the 78 body on the 77 frame..are the mounts in the same spots? i dont have the 77 home yet to check for myself. the frame on the 78 is solid, i will explore the option once the other truck is home..yea, for the rear i plan on running the d70.
Old Jun 28, 2009 | 06:25 PM
F250army45d
mounts should be the same only difference is you said one is short bed other probably a long bed. I would run the 77 F250 only drive train issue is the busted D44 I would find a open D44 or D60. As to the 460 going into the 78 should mostly bolt up may have to drill some holes to get the cross members lined up.
Old Jun 29, 2009 | 11:17 AM
1977f150xlt's Avatar
1977f150xlt
welcome to the dentside area, and nice rig! SoupCan™
nice to see another 4x4 short box, personally its my most favorite setup of any truck, hence its what i have!
what size of tires do you have on it in that picture? they look like 31"? maybe? or are they bigger?
also what kind of lift does it have? i think my sits up a little higher in the front than yours, hard to tell from pictures mind you,
here is my specs, mind you all the lift is in the suspension, no body lifts,
i know from the floor to the top rear wheel well edge, is 41"
the floor up too the top edge of the front wheel well is 37"
plus the 31" tires add about 1" when i finally put them on the truck,
so keep us updated on your truck, and more pictures!
-Brent
Old Jun 29, 2009 | 11:58 AM
76f350spercamprspeal's Avatar
Welcome to FTE!!
Its very good to have a new member on FTE!
I'M lovin' your '78,can't wait to see pics of the '77!
I Will be happy to help ya in any way I can!
But...I can't help ya with things about Danas and such...
I wish the best of luck to you,and can't wait to see what you do to your trucks(s).
Old Jun 29, 2009 | 08:56 PM
SoupCan™'s Avatar
SoupCan™
thanks guys....the tires on it now are 32 11.5 15s..i dono how much its lifted,brent, im getting 38 at the middle front wheel well, and 39 in the back... the rear has blocks under it, but they dont look like a normal lift block, they have a horn? on them? they come to a point toward the pig...
here is the numbers off the door plate..
F14HLCB3539 (W.B) 117 (color) v (G.V.W) F140 (body) AA4 (trans) G (AXLE) 16A 1978 (D.S.O) 86
Rich
ss74nova
33
Sep 12, 2014 10:12 AM
bkwdscrzr
Feb 12, 2013 11:41 PM
762tone
Nov 30, 2011 06:37 PM
Junkyardslug
Offroad & 4x4
Sep 5, 2000 01:06 PM
