Gear ??
Old Jun 27, 2009 | 10:26 PM
Dustin91ford's Avatar
Dustin91ford
Gear ??
I cant seem to find what the lowest gears I could put in my 91 f150. Whats the lowest gears ratio and what truck would i find them in?? thanks for the help!!!
Old Jun 27, 2009 | 10:36 PM
alxsnmr's Avatar
alxsnmr
Look up a gear vendor like summit racing or such since the rear axle is shared with a mustang you have alot of available gearing. You are pretty limited on factory gearing as the lowest factory gears were the 4.10s in the 8.8 and that was a rare truck to have them. You may be lucky to find 3.73s but the typical gears are the 3.55s.
Old Jun 27, 2009 | 10:45 PM
1966Tbird's Avatar
1966Tbird
i think you can go up to a 5.13 ratio with a d44 and 8.8 but if you do that be prepared to break a lot of stuff in the front end and maybe in the rear
Old Jun 27, 2009 | 11:04 PM
Dustin91ford
Anyone know what trucks these would be in so I can pull them at the junk yard??
Old Jun 27, 2009 | 11:30 PM
rikard's Avatar
rikard
Look for a vehicle equipment sticker on the drivers door jamb. The F150s with the 3.73 limited slip will have a axle code of B6.
regards
rikard
Old Jun 28, 2009 | 12:11 AM
Dustin91ford
Do they all interchange??
Old Jun 28, 2009 | 03:54 AM
17fordguy's Avatar
17fordguy
they will interchange but it is better to have a shop do the work because there are precise messurments that are required to make it work right and not grenade in the axle.
Old Jun 28, 2009 | 08:27 AM
1966Tbird's Avatar
1966Tbird
yeah if you asked if they interchanged don't even think about doing the gears yourself
