bad gas?
Old Jun 27, 2009 | 08:35 PM
JLBKOJACK33's Avatar
JLBKOJACK33
bad gas?
I have a 95 f150 4x4,302 auto.I just started noticing the battery volt meter going up and down when i stop and go.This is on the rear tank,last night it got worse the truck would cut off when coming to a stop.I replaced the fuel filter,cleaned the battery posts and clamps,tested the alt.,checked the wiring between the two.The reason i think it s bad gas is i took a trip and had to fill up at a diffrent gas station out in the middle of nowhere.Now i switched over to the front tank and it runs fine.Also when trying to use rear tank i had to fire it up by using the gas pedal just like if it had a carb.Maybe fuel pump going out?Any suggestions and no codes.Thanks for any help
Old Jun 27, 2009 | 08:41 PM
dustybumpers's Avatar
dustybumpers
might have water in it. try siphoning some out into a 5 gal bucket, and look for water in the bottom. got gas 1 time,ran like that, pumped it out had almost 5 gals water in it.
Old Jun 27, 2009 | 08:49 PM
JLBKOJACK33
Thats what i was thinking.We have had a lot of rain down here in Florida in the past two months.Thats what i get for using a diffrent gas station.Thanks
Johnks4x4
Feb 8, 2025 05:53 PM
mike L
39
Nov 23, 2014 09:33 AM
durbancic
Oct 12, 2010 05:18 PM
old blue 90
Jul 4, 2009 03:19 PM
