Boost gauge, compression fitting question
Old Jun 27, 2009 | 07:49 PM
locknload223's Avatar
locknload223
How tight do I tighten this thing down? I think I may have over tightened it, both ends. The gauge shows zero boost so maybe the ferrell cut the tubing???
Old Jun 27, 2009 | 08:05 PM
zx250's Avatar
zx250
Of the next Riffraff East
You cut or crimped the the line. Needs to be tight so I doubt you over tightened it.
HKusp's Avatar
HKusp
More than likely. It doesn't have to be too much more than 1/4 to 1/2 past hand tight really. I thought, maybe Barry is right.
Old Jun 27, 2009 | 08:08 PM
zx250's Avatar
zx250
That's true, but still I doubt it is over tight. More likely crimped.
Old Jun 27, 2009 | 08:15 PM
locknload223
I don't know how I could of cut the line just routing it, maybe it's kinked. I'll recheck in the morning. Should the gauge move a little at idle or gas it in neutral, mine's completely dead. This will help for tomorrow. I may go the Home Depot and pick up a couple new ferrells anyway. Thanks.
Old Jun 27, 2009 | 08:19 PM
zx250's Avatar
zx250
It won't move until you get on it. It's hard to get it to move in neutral or park.
Old Jun 27, 2009 | 08:30 PM
locknload223
Well hell, in that case, I'll take it for a spin in the a.m. first. Thanks, I'll report back tomorrow. Back to Mutant Chronicles . Thanks again.
Old Jun 27, 2009 | 08:31 PM
orng1's Avatar
orng1
Put a little load on it, the gauge doesn't go anywhere in parked but can fly when your on the move with a good tuner.
Old Jun 27, 2009 | 08:36 PM
locknload223
I even put it in drive, held the brake and brought it up a bit but the needle was still dead. I thought it needed a little load so I tried that, we'll see tomorrow. Thanks for the tip.
Old Jun 27, 2009 | 08:48 PM
zx250's Avatar
zx250
You probably don't have a problem. Get on it and watch it jump to life.
Old Jun 27, 2009 | 08:51 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Yep, drive it and get on it. My bet is that it comes right on up.
Old Jun 27, 2009 | 08:55 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Lol I did the same Bro. Hooked everything up and got nothing. Rang up the shop that supplied it complaining. Then took it for a drive and whalla, me got some boost. Take it for a drive m8
Now how do we get more
Old Jun 27, 2009 | 09:34 PM
Nick 99's Avatar
Nick 99
Please clarify for me.
If he was to disconnect the gauge end of the tube, wouldn't he get a volume of air coming out if it was installed correctly with diesel running?
Nick
Old Jun 27, 2009 | 09:38 PM
zx250's Avatar
zx250
At idle, he will have only a small volume of air moving, not enough to move the gauge.
Old Jun 27, 2009 | 09:43 PM
Nick 99's Avatar
Nick 99
Yes, but it would prove that he had no kink in the line!
Nick
