C6 adapters
Old Nov 6, 2001 | 06:48 PM
tbolt 460's Avatar
tbolt 460
C6 adapters
is there two different T-case adapters for the C6.And if there is,is there different length out put shafts??
Old Nov 6, 2001 | 11:49 PM
bronco_guy's Avatar
bronco_guy
C6 adapters
Yes there are different length tranny - t-case adaptors, one is a little over 8" & the other is a little over 5" in length. You will need the appropriate output shaft for the different length of adaptor. Which one do you have?
Ryan
'78 F250
Ranger/XLT Supercab
4x4, 400 (460 soon), C6
D44/D60, 4:10s, 33's
'71 Bronco,
302, C4, PS, PDB
Old Nov 7, 2001 | 04:56 AM
tbolt 460's Avatar
tbolt 460
C6 adapters
i have the 8in cast iron one and the shaft is to short.Do you know where i can find a longer shaft??
Old Nov 8, 2001 | 10:41 AM
79Supercab's Avatar
79Supercab
C6 adapters
If you have the 8" version and your output shaft on your tranny is too short, then you need the 5" version. These typically were found in 78-79 broncos and short box pickups. That is where I would start.
Ryan
'78 F250 Ranger Supercab 4x4
400, 4spd (460 & auto soon)
Dana 44/60 F&R, 4:10's, 33's
Dark Chocolate Brown
Old Nov 8, 2001 | 02:06 PM
tbolt 460's Avatar
tbolt 460
C6 adapters
does anyone where i can find the longer shaft for the C6 just in case i cant find the 5in adapter.I would like to have both setups
Old Nov 8, 2001 | 02:53 PM
79Supercab's Avatar
79Supercab
C6 adapters
What are you putting this into? If you are swapping a 4spd for a C6 in a '78 or '79, then you might want to stick with the short adaptor & shaft setup. If you go to a long adaptor and shaft setup, then you will be required to short your rear driveline because the t-case will be moved back.
Ryan
Old Nov 8, 2001 | 02:58 PM
tbolt 460's Avatar
tbolt 460
C6 adapters
a 83 Ranger,right now it has a T-18 but i think i want to change it over to a auto and i allreadt have a C6.
Old Nov 8, 2001 | 03:05 PM
79Supercab's Avatar
79Supercab
C6 adapters
Ahhh, then you're doing a bunch of mods anyway.
Ryan
Old Nov 8, 2001 | 03:12 PM
tbolt 460's Avatar
tbolt 460
C6 adapters
already done them.I just want another trans setup so i can change it over in a day
Old Nov 8, 2001 | 04:55 PM
ExplicitHP's Avatar
ExplicitHP
C6 adapters
