missing rear blocks???
Old Jun 26, 2009 | 11:50 PM
cjcathey2002's Avatar
cjcathey2002
I was contemplating putting in a set of f350 rear blocks to lift the back end of the truck up a little more. So i crawled under to take a measurement of my stock blocks. Am i missing the stock f250 blocks? Here is a link to the pictures:
http://www.flickr.com/photos/27494886@N07/3664624556/
and
http://www.flickr.com/photos/2749488...n/photostream/
If so, then I can get some 2" blocks from superlift that are for a 4x4, that come with u bolts for about 90 bucks. These should still work right?
Thanks guys.
Chris
Old Jun 27, 2009 | 02:28 AM
Zip's Avatar
Zip
It looks like you are to me.
When I had my 99 I put on a leveling kit and the rear sat low. I was going to put in the 350 blocks. Upon further inspection I came to the conclusion that I had no rear blocks.(the rear had been resprung with some honkin springs). I went to the wrecker and got some 250 blocks and had some new ubolts made.
I imagine the superlift blocks and ubolts would work as well.
Old Jun 29, 2009 | 09:22 AM
superduty4x4's Avatar
superduty4x4
Yup you're blockless alright.
Old Jun 29, 2009 | 09:59 AM
12ozd's Avatar
12ozd
They will work,but not your best option.
They are for adding 2" to your stock set up.They probably are not "tapered" to adjust for drive line angle as the stock ones would be.
Worth asking them about it first.
strokersace's Avatar
strokersace
From you sig:
2000 XLT Ex-Cab 4x2 6 spd, 2inch Leveling kit,
You've got a 2wd and from my understanding is that 2wd's do not have any lift block in the back. At least the one's I've seen don't. The F250 and F350 dually 4x4's have a 2" factory lift block and the F350 SRW 4x4's have a 4" lift block. Spring packs are the same. U-bolts are also longer/shorter depending on what you've got.
I'd say it looks typical for a 2wd truck.
Old Jun 29, 2009 | 10:03 AM
superduty4x4
Originally Posted by strokersace
From you sig:
Good catch Ryan. I want to add though that the early 99 F250 4x4's came stock with the taller (4" or so) rear blocks.
Old Jun 29, 2009 | 11:54 AM
12ozd's Avatar
12ozd
I never looked at that
Old Jun 29, 2009 | 12:31 PM
Zip's Avatar
Zip
From you sig:
Oops. I missed that as well
t147
Dec 15, 2011 11:52 PM
robby316
Aug 21, 2011 07:29 PM
Brushwacker
Aug 16, 2011 09:46 PM
makingaZJ
20
Apr 8, 2011 08:32 AM
93XLT150
Feb 15, 2011 05:40 PM
