Flathead 3 speed is STUCK!
Old Nov 2, 2001 | 03:10 PM
saxtonj's Avatar
saxtonj
I just rebuilt my '49 Ford F-1's 3 speed floor shift trans and now it is stuck in second gear. I took off the shifter and tower and it looks as if the synchro assembly has seperated and the assembly will not slide back where it should be. Does anyone know what could have caused this? I don't want to pull the trans and tear it down to only have it happen in the first 2 miles again like it did the first time.
Thanks for any help,
James
Old Nov 5, 2001 | 10:07 AM
saxtonj's Avatar
saxtonj
Tore open the trans...AGAIN. Turns out the new synchro assembly has "seperated" and is causing the problem. I wonder if it was something I did/didn't do, or problem with the assembly.
James
Old Nov 5, 2001 | 11:14 AM
lanero's Avatar
lanero
Does that trans have shift stops?
Maybe the stops need adjustment.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
Old Nov 5, 2001 | 11:25 AM
saxtonj's Avatar
saxtonj
I don't think it has stops. The "outside" of the synchro assembly is slinding to the rear of the trans, while the "inside" is staying put. The "inserts" are exposed after shifting into second....if that helps any in your diagnosis.
J
Old Nov 27, 2001 | 01:51 AM
mrlaserboy's Avatar
mrlaserboy
Old Nov 27, 2001 | 10:42 AM
saxtonj's Avatar
saxtonj
I hope this helps someone.... my output shaft was wrong. It allowed second gear to slide back to far. It was about 1/4" too long.
james northen
Jul 30, 2006 07:55 PM
jamesj
Nov 10, 2005 07:47 PM
james500
Jul 23, 2005 07:12 AM
88fordf150
Jun 24, 2005 01:32 AM
