Sponsored by: Real Truck
TrueTrac install
Old Jun 25, 2009 | 06:16 PM
a-rod's Avatar
a-rod
TrueTrac install
Alright guys I finally got my Detroit TrueTrac for the rear of my truck, I thought maybe I could install this but Im hearing differently, I thought they would just bolt right in after sliding the axles out. Anyone installed one or know how they go in? Should I just have a shop do it? Thanks for any help!
Old Jun 25, 2009 | 10:15 PM
racinghoss's Avatar
racinghoss
Edit: I mixed up the model you have. If you already read what I previously posted, disregard it.
I think the TrueTrac is a full case LSD. You would be better off to just let someone do the work for you. Messing it up even just a tiny bit could be disasterous.
Old Jun 26, 2009 | 08:42 AM
a-rod's Avatar
a-rod
Yeah thats kinda what Im thinking
Old Jun 26, 2009 | 11:06 AM
cartmanea's Avatar
cartmanea
I installed a TrueTrac when I did my gears. You aren't messing with the pinion, so all you need to worry about is getting the backlash correct and checking to make sure the mesh pattern is descent. Also, you must get the carrier bearing preload correct, so install .0015-.0020 more shim than when the carrier slides in easily.
Old Jun 26, 2009 | 01:21 PM
a-rod's Avatar
a-rod
You already lost me, I better just have it done. LOL.
Old Jun 26, 2009 | 01:28 PM
cartmanea's Avatar
cartmanea
You can order Randy's Ring and Pinion differentials book, it explains everything in great detail and is about $23. That was my resource in changing gears for the first time. The only special tools you need is a press to install the carrier bearings (get new ones). The rest is just shimming the left and right side of the carrier to get the proper bearing preload and backlash.
Joel Cassell
Jan 12, 2016 09:29 PM
CTC01
Nov 19, 2014 11:44 AM
Gerby Dutchy
2009 - 2014 F150
Nov 14, 2014 01:54 PM
xupkid2
6.4L Power Stroke Diesel
Oct 30, 2011 06:38 AM
mcpga
Sep 30, 2010 04:27 AM
