Engine swap
Old Jun 25, 2009 | 05:06 PM
kovacik76's Avatar
kovacik76
Question Engine swap
I am tired of my 2003 6.0 crapping out. Has anyone swapped in a 7.3 and what will I need from the donor truck
Old Jun 25, 2009 | 06:45 PM
heavyiron's Avatar
heavyiron
If you want to keep the truck long term, I'd suggest putting in a Cummins. Yes its quite a project and its costly, but you will have a geat truck. The 7.3 is a good engine, but its not worth the cost to retro fit IMO. Either way, sounds like quite the project.
Old Jun 25, 2009 | 07:01 PM
SHAWN056.0's Avatar
SHAWN056.0
Hate to say it but i'd go with the cummins also. When i first bought my truck i had no idea of all the problems people had with these trucks. I almost did the cummins swap just cause i love this body style and the interior over the dodge. I haven't had any problems with mine but soon as i do it's getting stuffed with a cummins.
Old Jun 27, 2009 | 10:25 AM
fordboy2's Avatar
fordboy2
I have also been considering dumping my 6.0 as I am tired of the trouble also and I have not had that many problems. but more than any other newer vehcle I have owned. One problem with the 7.3 swap would be if they ever tested for emisions, atleast on my 06. Since they offered the 7.3 in your model year this may not be an issue. I would think your cost would be about the same as doing a cummins swap, but with adaptors on the cummins swap you could keep your trans. The easiest way would be to buy a whole truck to do the 7.3 swap and probably the most economical so the little odds and ends dont kill ya in price. either way good luck.
Old Jun 27, 2009 | 12:22 PM
heavyiron's Avatar
heavyiron
The other thing to consider is that the 6.0 is actually a very strong engine IF you fix the flaws it has. In reality you could probably turn your existing 6.0 into a reliable beast for less than a cummins swap would cost you.
Old Jun 27, 2009 | 12:44 PM
heavyiron's Avatar
heavyiron
Sorry, itchy mouse finger!
Old Jun 27, 2009 | 02:42 PM
fordboy2's Avatar
fordboy2
I would agree to a point. I am just frustrated with how unreliable this truck is quickly becomeing. The local dealer cant seem to figure out what is wrong and I am worried once I run out of warrenty it is going to cost a fortune to get peolple to work on this thing. The advantage to going to the cummins would be the simplicity and a average person could work on it due to the lack of electronics. Now would it be worth the cost, that is only for the beholder to decide.
Old Jun 27, 2009 | 04:13 PM
Dustball8504's Avatar
Dustball8504
The only reason I would swap out my 6.0 if it dies for a cummins is to build serious power. Other than that I'd say I'm gonna keep a 6.0 in her...I love that crisp sound out of my stacks!
Old Jun 27, 2009 | 04:56 PM
69cj's Avatar
69cj
Ca. is supposedly going to start emissions testing/inspection on light duty diesels next year. If they do you are probably not to far behind. You could end up with a dynamite truck that cannot be put on the road.
Old Jun 27, 2009 | 08:59 PM
SHAWN056.0's Avatar
SHAWN056.0
Unless you put the same year model engine as you truck in it.
Old Jun 27, 2009 | 09:37 PM
fordboy2's Avatar
fordboy2
it has to be same year or newer to pass emisions, and be legal.
Old Jun 28, 2009 | 07:02 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
^^ What he said!
Old Jun 28, 2009 | 09:26 AM
69cj's Avatar
69cj
Agreed but to do that you have to take the truck to a referee station and get a special tag applied to the radiator frame rail. Buddy of mine put a Chevy V-8 in his jeep ans it was rejected not because of the engine but because that year engine never had a stickshift behind it. They knew because you also have to use the donors stock computer and all that info is in there. He finally found a guy that used to do programming for the auto companies and he was able to write a program for the stock computer that let them pass it. A big pain in the A**. Also cost him a number of greenbacks for the guy to do it.
Old Jun 28, 2009 | 10:27 AM
FlyCanadianGuy's Avatar
FlyCanadianGuy
Cummins FTW.
Old Jun 28, 2009 | 08:13 PM
06silvercrew's Avatar
06silvercrew
Whats unreliable about the 6.0 aside form EGR, head gaskets and injectors???? EGR Delete= $couple hundred bucks. ARP head studs, price varies, good set of injectors- All this will prob cost less then an engine swap and be super reliable.
