im going to rebuilt my 360 soon. its in my 76 f150 4x4. this truck is my mud truck. i want a cam that puts out some tourqe. any advice on a cam to pick?
I have luck with a Comp XE256H in my 406 that I put in my truck. Specs are listed below. I also bought the entire "K-cam" kit and installed the timing set advanced four degrees. I get huge power between 1000-4000 rpm. Totally happy with the setup!
<TABLE style="BORDER-COLLAPSE: collapse" borderColor=#111111 cellSpacing=0 cellPadding=3 width="98%" border=1><TBODY><TR><TD align=middle bgColor=#eeeeee>Competition Cams Part
Number </TD><TD vAlign=top align=middle bgColor=#eeeeee>
Application </TD><TD align=middle bgColor=#eeeeee>Power Range</TD><TD align=middle bgColor=#eeeeee>Idle
Quality/special requirements</TD><TD align=middle bgColor=#eeeeee>Valve Lift
Int/Exh
</TD><TD align=middle bgColor=#eeeeee>Duration Adv.
Int/Exh in degrees
</TD><TD align=middle bgColor=#eeeeee>Duration @.050
Int/Exh in degrees
</TD><TD align=middle bgColor=#eeeeee>Lobe
Centerline
</TD></TR><TR><TR><TR><TD align=middle>#K33-234-4
Xtreme Energy series XE256H grind
</TD><TD align=middle>352 390 406 410 427 428 FE block Fords 1963-1976 with hydraulic flat tappets
</TD><TD align=middle>1000-5200 rpm</TD><TD align=middle>Strong torque thru low and mid-range. Good economy. Mild idle
</TD><TD align=middle>487/493</TD><TD align=middle>256/268</TD><TD align=middle>212/218</TD><TD align=middle>110</TD></TR></TBODY></TABLE>
how about a 390 crank and rods, that'll put out some torque. Then you combine that with a cam like that and you'll feel like your trucks on the funny gas. I mean you're rebuilding anyway. And if you care you get better mpg. So you can mud longer without refueling. LOL
I think we worked this out a while back. With the shorter rod, the 360 piston height works, but I need to recheck that. I'll repost if I find that info. Good point though, all that stuff MUST be checked in a particular engine to make sure it fits, as blocks can be decked, heads resurfaced etc, which can make a real problem out of something that is "supposed to work" on paper.
