Trivia question Thread
Old Nov 12, 2018 | 05:20 PM
  #31
wpnaes's Avatar
wpnaes
I wonder if it’s windy there? Or do birds soar there?
Old Nov 13, 2018 | 07:16 AM
  #32
Flip4ford's Avatar
Flip4ford
Unless it is 390 or Coyote and with the above clue I figured it out :-) Is there a castle there with that name? Or is it somwhere else?
What is the most popular selling vehicle ever? F150 or Toyota Corolla?
Old Nov 19, 2018 | 11:30 PM
  #33
Flip4ford's Avatar
Flip4ford
Toyota--
Ford is highest selling truck for like the last billion years or so though :-)
Old Nov 20, 2018 | 12:09 AM
  #34
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Flip4ford
Mercedes
Austin Healey
Toyota
Jaguar
Rolls Royce
Which one (ones) never made cars in the USA?
I know this post is 8 years old, but I didn't see an answer, so...
Austin Healey & Jaguar
Edsel was never a "luxury" car, it was sandwiched in between Ford & Mercury.
1958/60: Ford - Edsel - Mercury - Lincoln.
Old Nov 20, 2018 | 05:36 AM
  #35
Flip4ford's Avatar
Flip4ford
good answer- My dad has a '60s edsel "kit" or "project" :-)
Old Nov 20, 2018 | 06:04 AM
  #36
Tedster9's Avatar
Tedster9
Early Fords were offered in a variety of colors, but it was observed that certain paint colors dried quite a bit faster than others (and yellow or red or blue cost more) and therefore production was speeded up, so they did that by offering "any color you want, so long as it's black".
Old Nov 20, 2018 | 01:40 PM
  #37
NumberDummy
The thing is, vehicles were not painted, they were varnished! One entire floor of FoMoCo's huge Highland Park plant was devoted to varnishing bodies.
Two coats were required, after the first coat dried, it was sanded, then another coat was applied.
This was a very involved process that took two days. Dust was a major problem, had to be removed so it wouldn't settle on the drying varnish.
Ford said "you can have any color, so long as it's black," because black varnish dried the quickest.
In 1924, DuPont invented automotive paint that they called Duco. First vehicle painted with it: 1924 Oldsmobile.
DuPont was a major shareholder in GM, for many years, Oldsmobile was GM's "experimental" car. 1925 Oldsmobile was the first US car to have chrome plating.
Old Nov 20, 2018 | 02:11 PM
  #38
Tedster9's Avatar
Tedster9
Varnish? I thought it was enamel. Or what we would call enamel today.
here's something:
You've heard the phrase umpteen times: "You can have any color as long as it's black."
It's one of the most famous quotes attributed to Henry Ford - his retort to customers asking about color choices for the Model T. No one seems to know whether Ford actually spoke those words.
But that quote is the reason why generations believe all Model T's were black.
Too bad it's not true.
Indeed, Model T's came only in black for 12 out of 19 model years. But in those seven other model years other colors - such as green, bright red, dark blue, brown, maroon and gray - were available.
Black dried quickly
The Model T was introduced Oct. 1, 1908, and through the 1913 model year buyers had a choice of several colors, including black. Then, in 1926 and 1927, colors included green, light blue, brown, maroon - and, of course, black.
Black was the only color the Model T came in from 1914 through 1925, and the reason was economics, not style. Black was the only color paint that could be dried quickly, and speed was important at the Ford plant because of its enormous volume.
According to Model T expert Guy Zaninovich in Ann Arbor, Mich., cars were painted using a process called japanning, which today would be called baked enamel. "It was first used in the mid-1800s for decorative items imported into America," Zaninovich says. "A piano has a shiny black surface that almost looks like plastic rather than painting because it was done with the japanning process. It leaves a very hard and durable surface. The only pigment that it worked in is black. If japanning worked in hot pink, all Model T's would have been hot pink."
Akron Paint & Varnish Inc., the 125-year-old Ohio company that made the original black paint for Henry Ford, is still around, and it has the formula. CEO David Venarge says the formula came with the two founders from Germany. "The formula used tung oil, a cheaper replacement for linseed oil, car black pigment plus gilsonite, a mined mineral," he says. "The paint was also used on mattress buttons, hooks and eyes, bobby pins and other hardware."
Bodies needed fast
By 1914, Henry Ford had implemented his moving assembly line. Having bodies ready for this faster method of assembly was key to hastening the rate of production.
Going to all-black cars was a wise decision because the young Ford Motor Co. had more orders for the Model T than it could fill. According to Ford, in 1914 alone, 300,000 Model T's were made, while competing automakers had a combined production of about 280,000 cars.
Source:
http://www.autonews.com/article/20030616/SUB/306160713/model-t-had-many-shades%3B-black-dried-fastest
Old Nov 20, 2018 | 02:27 PM
  #39
NumberDummy
DuPont's Duco was enamel paint, but there was no such thing prior to 1924.
DuPont also invented nitrocellulose lacquer, don't know what they called it, but inre to FoMoCo, only 1925/39 Lincoln L/K/KA/KB models were painted with it.
1936/48 Lincoln Zephyr and 1940/48 Continental were painted with Duco enamel.
All 1935/56 Packard's were painted with nitrocellulose lacquer.
The paint tended to "spiderweb" so when repainted with this lacquer, the paint had to be sanded down to the primer coat, a time consuming PITA!
btw: I have a 1925 Baldwin Parlor Grand, it's black varnish and has alligatored (cracked) because it was exposed to the sun while sitting in the living room 1939/2001.
Old Nov 20, 2018 | 07:20 PM
  #40
Tedster9's Avatar
Tedster9
Do you take requests. "Rockin' Pneumonia - Boogie Woogie Flu"? Johnny Rivers 1972
Old Nov 20, 2018 | 10:20 PM
  #41
NumberDummy
I prefer Ragtime, Scott Joplin comes to mind. Or if you wish, two favorites of mine: Rachmaninoff's 2nd Piano Concerto or Mussorgski's Pictures at an Exhibition.
Or I can fire up the three manual Gulbransen and boom out Bach's Tocatta and Fugue in D Major.
Old Nov 20, 2018 | 11:00 PM
  #42
Tedster9's Avatar
Tedster9
That's pretty cool. I don't care for a lot of classical music, but they don't have any ****ing commercials, which I cannot stand, on the local college FM station. There's a "Pipe Dreams" program where they play bad *** restored church organs on Sunday nights. With a subwoofer it's pretty authentic sounding on my home stereo. I'm told playing those beasts is the musical equivalent of flying the space shuttle. When I hear Bach's Fugue I expect the Phantom of the opera monster to pop up. Creepy!
Old Nov 21, 2018 | 12:21 AM
  #43
NumberDummy
Pipe Dreams is broadcast here on a local public radio FM station (no commercials). It's the favorite show for members of LATOS (Los Angeles Theater Organ Society).
I have a friend who is restoring the 4 manual Wurlitzer that was originally located in the Pig & Whistle Restaurant in Hollywood.
I have another friend who built a building in his back yard for his 3 manual Wurlitzer.
He has to notify the neighbors when he fires it up, because...the first time he played it, several neighbors complained of broken windows!
As dramatic as Toccata and Fugue is, Also Spach Zarathustra by Richard Strauss is even better. It's the opening music of 2001 - A Space Odyssey.
Our local (and only) strictly classical music station is KUSC owned by the University of Southern California.
Their pledge drives crying for money are disgusting, as this is one of the most (if not THE most) wealthiest universities on the planet.
For many years our classical music station was KFAC, the station was founded in the early 1930's by the local Auburn-Cord-Duesenberg dealer.
Both the Cadillac & Packard distributors founded radio stations, with KFI (Earle C. Anthony, Inc.) being the most famous, it's still on the air today.
Ah yes, Phantom of the Opera, I prefer the silent version starring Lon Chaney with ******* Perry playing the organ.
Old Nov 21, 2018 | 05:56 AM
  #44
Tedster9's Avatar
Tedster9
I think he ended up pitching for the Giants, didn't he?
Yeah my Dad went to Grinell, a small school here in Iowa, on the GI BILL. In those days, Uncle Sam would pay the tuition of any school, regardless of cost. If you got accepted that is. These days it's just a monthly stipend that hardly pays anything, still a good deal, but... Anyway they are sitting on about a $2 billion dollars with a B endowment, yet charge $53,000 a year for tuition, room, and board, and they used to hit up dear old dad like clockwork every year for donations when he was scraping by on Social Security. They claim to have a "commitment to social justice". Suuure. Take another Bong Hit.
If people think "College Should Be Free", certainly the professors will be willing to volunteer their services gratis, and the Colleges can draw off their endowments instead of hitting up the po' folk for charity and tax hikes on people who don't even want or need to go to college. Gah. For the "best and brightest" they sure are cranking out hordes of stupid ****ers these days.
Yeah for some reason I didn't realize, there is actually an "Associated Pipe Organ Builders Association" or APOBA.org (undoubtedly you're a member in good standing) I like the sound of "honky tonk" pianos. This is done in many songs and movies by using what's called a "tack piano", tacks or nails are installed on the hammers to give that distinctive old-timey or saloon sound. I think the strings are are detuned a bit.
Do you tune your Baldwin piano yourself? That's a whole 'nuther deal.
Old Nov 21, 2018 | 07:51 AM
  #45
Flip4ford's Avatar
Flip4ford
man you guys woke this old thread up I really enjoyed all the comments!
