headlights
Old Jun 25, 2009 | 05:39 AM
jmmartin's Avatar
jmmartin
headlights
Lastnight i pulled the light switch out, parks come on, open drivers door and heads come on... any thoughts?
Old Jun 25, 2009 | 12:35 PM
deano-was-his-name-o's Avatar
I had my switch fry and it made my lights do strange things. I would check your headlight switch
Old Jun 25, 2009 | 03:48 PM
macman85602's Avatar
macman85602
most likely you will need to replace your headlight switch. It is a major pain to install so when you replace the switch do the headlight relay upgrade as well. There should be someone who has done the upgrade coming along to tell ya how.
Scott
Old Jun 25, 2009 | 04:03 PM
rupejosh's Avatar
rupejosh
Scott
i have done the mod its really easy.the best way to explain it is use one of the headlight wiring harness's to cut the high low beam wires and use the wires as signal wires to a relay.i have a wiring diagram in my gallery if you want to take a look
Old Jun 25, 2009 | 04:44 PM
macman85602
Not trying to hijack the thread but what kind of relays did you use? Might be useful for JM also.
Scott
Old Jun 25, 2009 | 04:48 PM
rupejosh's Avatar
rupejosh
Scott
i just went to autozone and got the universal relays they are about 3 bucks a piece i
think and to do the mod you need to of them and plenty of 10gauge wire i think it cost me about $15 to do my mod
Old Jun 25, 2009 | 04:52 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
In the "'80-'86 Tech Tips, Tricks and Projects:" Sticky there is a thread for the headlight relay mod.
The link is: Whiter Whites, Brighter Brights Headlight Relay Conversion
-Enjoy
fh : )_~
Old Jun 25, 2009 | 05:37 PM
goodB0Y's Avatar
goodB0Y
Keep in mind that the relay mod done on a canadian truck the way it's stated will have your HI beams on while driving... I dont know where "Deep in the piney woods" is... but if it's in canada there's a good chance it will have DRL's... I think it's mostly us canucks with DRL's but there might be some US trucks with it as well.
Daytime running lights power your hi-beams at a lower voltage for day time driving... but it's enough to switch on a relay! If you get your relay switching power from the existing headlights then your going to turn on the relay with the DRL's ... which will trigger your hi-beams.
Old Jun 25, 2009 | 05:41 PM
jmmartin's Avatar
jmmartin
it sounds like i am gonna have to finally change out the switch then. the dimmer coil already has a burnt spot on it that i saw oh,,,,,,,,,, about a year ago. being the tight wad that i am i put it back in like it was after a little brush work to try to clean the spot up...
Old Jun 25, 2009 | 05:43 PM
jmmartin's Avatar
jmmartin
No DRL here, im down in East texas close to louisiana and to the gulf
SixOhCrew
Sep 13, 2019 10:06 AM
oldfordisbetter
Jan 6, 2011 08:29 PM
bobbyg
6.7L Power Stroke Diesel
Sep 20, 2010 07:57 PM
Carnivore
2004 - 2008 F150
Feb 4, 2010 07:55 PM
staffbuoy
Sep 24, 2004 06:15 AM
