no heater
Old Sep 21, 2004 | 05:50 PM
staffbuoy's Avatar
staffbuoy
Question no heater
Hi people heater motor wount come on.91 explorer not turning on
Old Sep 21, 2004 | 06:36 PM
holiday187's Avatar
holiday187
heater core??
Old Sep 21, 2004 | 09:51 PM
mustangsvt's Avatar
mustangsvt
lol thats funny my '00 V6 aint turning on the heat and it was really chilly this morning. blew A/C the whole way to work with it turned all the way on red
Old Sep 21, 2004 | 09:54 PM
85e150's Avatar
85e150
Heater motor won't come on?
Fuse
Switch
wires
motor itself.
Old Sep 22, 2004 | 07:36 AM
Golfmore's Avatar
Golfmore
Even though there is no heater motor, is there warm air coming out of the vents?
Old Sep 22, 2004 | 09:55 AM
ajguzik's Avatar
ajguzik
If it's blowing cold air, then it sounds like the fan motor is OK. Sounds like the blend door is broken. With winter around the cornr, I finally performed the blend door fix last night. if I hadn't dropped a 1/4 rachet behind the plenm, I would have been done in 30 minutes.
Old Sep 22, 2004 | 02:17 PM
staffbuoy's Avatar
staffbuoy
Question turn switch
I turn the switch on full or med blower motor woun't come on. I check the fuse good. Put a test light on the plug@ the motor light come on.Change motor still the same.How hard is it for to take the heater controls out of the dash to check got me puzzel .Thanks people any reply will be a help @ this point.
Old Sep 23, 2004 | 10:25 PM
handx2's Avatar
handx2
is it blowing cold air?if it`s blowing anything at all,it`s not the motor.would most likely be the plenium door.
Old Sep 24, 2004 | 12:10 AM
Dialtone's Avatar
Dialtone
Check for these two additional items that may cause your blower motor not to work.
1. Ground is missing or has high resistance.
2. Power lead has high resistance.
I suggest leaving the motor plug connected, stick a straight pin thru wire insulation and check voltage on power lead. If less than 12 you have a high resistance somewhere in wiring path (most likely in the blower motor speed control resistor pack). Do the same for the ground lead checking the resistance to a good frame / body ground point.
If these two check out OK but blower motor still not working, replace blower motor again as you may have gotten a bad replacement.
Dialtone
Old Sep 24, 2004 | 06:15 AM
staffbuoy's Avatar
staffbuoy
thanks I took the dash apart to check the heater controls out they seem to be good.Its got to be the motor
Nov 27, 2012 06:00 PM
Jul 21, 2002 08:34 AM
LK
Nov 30, 2001 11:28 AM
karljay
Feb 9, 2001 07:27 PM
RRL78
1978 - 1996 Big Bronco
Oct 17, 2000 12:10 PM
