Sponsored by: Innova
Need some help!
Old Jun 24, 2009 | 06:35 PM
stroken's Avatar
stroken
Need some help!
i have a kenwood ddx712 headunit, amped door speakers and a 1000 watt ma audio amp powering two kicker subs.
My problem is i had a cheap amp and subs in before and put them in my girlfirneds truck, i bought the new ma audio amp and subs off line and hooked them up EXACTLY like my old ones were and they dont work, amp has power, green light is on not red. the gain is all the way up and the bass control on the head unit is all the way up also and the subs are just brley moving. every now and agian you could hear them kick on but nnnnnooooooo where near how they should.
Can anyone help?
Old Jun 24, 2009 | 07:30 PM
mtondreo's Avatar
mtondreo
check the impedence on the subs (ohms) if they are moving a little bit, sounds like they could be wired wrong (best case scenario)
Old Jun 24, 2009 | 08:02 PM
ReAX's Avatar
ReAX
Do you have a DMM? Set the DMM for VAC (volts AC) and meter the speaker outputs. If you have input and power, then they should have more than 30v.
How do you have the speakers hooked up? All positives together or positive to negative. How does your manual say to hook up the speakers, ie bridged, lowest impedance, two pair of outputs?
Old Jun 25, 2009 | 03:13 AM
Don S.'s Avatar
Don S.
Better yet unplug the amp speaker wires from the box and tell us what your Ohm reading is from the terminal cups.
Also helpful is model subs and amp.
stroken
Jun 24, 2009 11:20 PM
slenser
Apr 9, 2006 02:18 PM
Cool1996
22
Nov 9, 2005 02:37 PM
boxcar1974
Aug 2, 2005 08:08 PM
eightysix
Mar 23, 2002 12:12 PM
