Brake controller
Old Jun 24, 2009 | 05:15 PM
Merlin8188's Avatar
Merlin8188
Brake controller
Hello all, new to the forum. Recently purchased an 01 excursion 7.3 I needed a tow vehicle with better mileage. I installed a Prodigy brake controller a few days ago. It powered up, but didn't get a chance to set the level. I went out the next day to hook up the trailer and there is no power to the Prodigy. I checked the fuse under the steering wheel and the 7.5 fuse in the engine compartment. All ok. Took an ohm meter and getting power for activating the foot brake, but nothing else. Is there another fuse/relay to check? I need to get this up and running, have a divisional race this weekend.
Cliff
Old Jun 24, 2009 | 06:32 PM
ReAX's Avatar
ReAX
On the prodigy controller, the wire colors should be Red=Brake cold, White Ground, Black Power and Blue=controller output. First I would check for 12v on the white and black wires. If you don't see voltage, then move to a good chassis ground instead of the white wire. If you have power, then the ground is bad. If you still don't have power, you have a problem on the power wire.
If your in a hurry, it might be quicker and easier to run a new 8-10ga wire and fuse from the battery to the controller.
Old Jun 24, 2009 | 07:11 PM
Merlin8188's Avatar
Merlin8188
Tried again with the ohm meter and got ground-white wire and positive-red wire for activating the brake. Result is 12 volts. tried the white-ground and black-positive and result in no reading. Just no positive power coming thru the black wire. Any other suggestion? very maddening...
Cliff
Old Jun 24, 2009 | 07:18 PM
ReAX's Avatar
ReAX
Just checking every fuse for continuity and running a new power wire.
Old Jun 25, 2009 | 06:47 AM
DSMMH's Avatar
DSMMH
Cliff
Did you have the ignition key ON when you checked for power to the BLACK wire?
DSMMH
Old Jun 25, 2009 | 12:34 PM
Merlin8188's Avatar
Merlin8188
Yes, the key is on. There should be constant power to the black wire.
I may have to do run a wire straight the fuse box or battery to power up the prodigy.
Cliff
Old Jun 25, 2009 | 12:52 PM
mohrds's Avatar
mohrds
Did you wire it yourself or are you using the optional Prodigy - Ford harness??
Under the hood in the power distribution block there is a 30Amp fuse in Location 110 for the trailer brakes.
Under the Dash there is a 20Amp fuse in location 13 for the brake controller.
Doug
Old Jun 25, 2009 | 04:02 PM
Merlin8188's Avatar
Merlin8188
Thank you for the info. Just pulled #110 30a fuse and it's blown. It's the one I didn't check. Now running down to the Ford dealer to pick up a new one. Thanks again Doug!
Cliff
Old Jun 26, 2009 | 09:23 AM
BroncoEx's Avatar
BroncoEx
Doug...... I'm not even part of this thread, but with detailed instructions like that, even I could do it. That was awesome.
Old Jun 26, 2009 | 10:45 AM
mohrds's Avatar
mohrds
It was as simple as looking through my owner's manual. I keep a PDF copy of it that I downloaded from Ford's site right on my laptop.
I love being able to help out others because I have received so much time and money saving help from others.
I love this site!
Doug
F2250crew
Oct 21, 2014 04:39 PM
dieselscout80
Sep 26, 2014 07:57 AM
beeser
Nov 8, 2013 05:14 PM
kailor
Aug 11, 2008 04:27 PM
RockyRacoon
All Things Towing
Aug 18, 2003 02:41 PM
