Bed bolt removal
Old Jun 24, 2009 | 09:57 AM
emgee's Avatar
emgee
Bed bolt removal
What is the most efficient way to remove the carriage bolts from the box? I don't care about the box because it's toast and the bolts are so rusted I can't remove them. I can't even get a nut splitter on some of them. They've been soaked with WD-40, hammered on, heated etc.
Old Jun 24, 2009 | 10:08 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Hot Wrench ... Burn the heads off.
-Enjoy
fh : )_~
Old Jun 24, 2009 | 11:27 AM
Diesel_Brad's Avatar
Diesel_Brad
Burning off the heads doesnt work, The shank of the bolt will not go thru the bed. Weld large nuts on to the head of the bolt(weld it right) and impacting it off while holding the nut w a wrench.
Old Jun 24, 2009 | 12:31 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Or just weld the head to the bed and then use an impact from underneath.
Old Jun 24, 2009 | 12:39 PM
hoxiii's Avatar
hoxiii
Torch them off from underneath.
Or torch them off from above and hope rust has worked in your favor as you lift it off.
Old Jun 24, 2009 | 06:52 PM
cadunkle's Avatar
cadunkle
If you don't care about the bed I'd grind the heads and/or bed and pull the bed off, then enjoy more room to work. Either grind or sawzall them off at that point.
Also, WD40 sucks as a penetrant. Get some PB Blaster or Kroil. Few heat/soak cycles loosens most stuck fasteners.
Old Jun 26, 2009 | 01:46 PM
whatthencuz's Avatar
whatthencuz
i had to use a cutting wheel to cut the heads of the bolts (i didnt care about cutting the bed up because i was getting another one) when the head came off the bolts they slipped through and i removed the bed, afterwards i just came back in with the cutting wheel and cut the bolts in half to take them off. when i put the new bed on i welded the head of the bolts to the bed so i could get a good grip. I took the truck to the body shop and i had to buy yet another bed so they trashed the other one wit the welded bolts. When they installed the new bed they got vise grips to hold the bottom of the bolt while they used a wrence to tighten the nut.
Old Jun 26, 2009 | 05:25 PM
uncle.stosh's Avatar
uncle.stosh
As stated you CANNOT just grind the heads off and pull the bed off (unless your cross bars are rusted to hell).
They are oval shaped and are shoulder bolts. Cutting the heads off only makes them HARDER to remove.
Weld something on to the heads and have someone hold them while you get underneath.
It's not so easy to burn them off from the bottom either because of the gas tank. You cannot safely get at them without removing the tank.
Also, I would try and save the bolts if you can. New ones are about $15 EACH from the dealer.
Old Jun 26, 2009 | 06:00 PM
Franklin2's Avatar
Franklin2
I have removed two beds by grinding the heads off the bolts. It seems the ones I took off had a big enough hole in the crossmembers for the shoulder to fit through. It's a pain in the neck however you do it.
Old Jun 26, 2009 | 07:04 PM
emgee's Avatar
emgee
I have all the bolts from the 95 box except one (had to be ground off). The missing bolt (one of two) has the square shank so I think it may be the same as the older 80-86 bolts. I checked at my Ford dealer and they want $150 for a kit of 6 bolts and nuts for a 95 box and they're not available individually. I'll try LMC and get a couple of bolts for the 80-86 box. The 95 box uses 4 lozenge shank carriage bolt and 2 square shank carriage bolts.
Old Jun 26, 2009 | 10:18 PM
86bigred's Avatar
86bigred
all i did was mig weld the carrage bolts to the bed and lifted the bed off.my bed was toast as well.had no problems lifting the bed off.
Hometown Pride's Avatar
Hometown Pride
Why dont people use regular nuts and bolts, when there tight they shouldn;t move even if there is a bit of play when you put them in.
Old Jun 26, 2009 | 10:33 PM
uncle.stosh
Why?
Ever seen grade 5 bolts fail when you have about 1000-1500 lbs of something in the back, the load shifts and and bed comes flying off?
That's why.
Old Jun 26, 2009 | 10:34 PM
Franklin2's Avatar
Franklin2
A regular headed bolt seems to snag on anything you try to slide into the bed. If you use regular bolts, you have to use very large washers under the heads, since the hole in the bed is huge, but the threads through the frame are only 1/2".
I compromised on the two beds I did, and used 1/2' carriage bolts. To get them tight, I put two flats on the rounded part of the bolt so I could get someone to put a adjustable wrench on them to hold them till I got them tight. I used large enough washers so the square part of the carriage bolt fit down into the washer.
Old Jun 26, 2009 | 11:02 PM
Hometown Pride
Why?
That's why.
No I have not seen grade 5 bolts fail, especially 8 of them at once. There is a place near me called Fastenal, they could supply me with a bolt and nut with any strength I need. Whether it be for holding planes, trains, or massive presses together I'm sure they would be up to the challenge of holding a box to truck. Not a 100 % but I think so.
