Violent outofcontrol Shake
Old Jun 24, 2009 | 09:34 AM
highrise4x4's Avatar
highrise4x4
hey guys i own a 1996 f150 5.0 4x4 5spd its lifted 6 inches with 35s its a short bed single tank now when im driving down the road its fine on the highway its fine now when i hit a series of bumps the whole truck shakes violently even after im on flat road it shakes so bad it knocks anything i have on the dash on to the floor im at a loss i have no clue what it could be..any help is appreciated thanks guys
Matt
Old Jun 24, 2009 | 11:08 AM
nstueve's Avatar
nstueve
Matt
Check your drive shafts and make sure your ujoints are tight. Does it shake in 4x4 or after you leave 4x4? It could be anything in your drive line you'll need to narrow down where the shake is coming from before you can refine to what the problem actually is. does the shake come from the front or the rear? Are you hearing anything with the shaking>?
Old Jun 24, 2009 | 11:09 AM
17fordguy's Avatar
17fordguy
check your shocks and springs somthing may have broken
Old Jun 24, 2009 | 12:19 PM
highrise4x4
well its just when driving in normal 2wheel it feels like its the front end i just replace the ujoints so its not that but when it happens all the stuff flys off the dash
Old Jun 24, 2009 | 12:23 PM
alxsnmr's Avatar
alxsnmr
Have you checked your ball joints, tie rod ends, steering box play, wheel bearing, and all the suspension connections like the axle pivots for excess play?
Old Jun 24, 2009 | 01:44 PM
highrise4x4
ive checked everything except the axle pivots how do i do that the rest checks out
Old Jun 24, 2009 | 01:53 PM
alxsnmr's Avatar
alxsnmr
Crawl under the truck and look for cracked rubber. Also have a helper move the wheel to see displacement on the rubber as the wheel turns.
Did you use a drop pitman arm or something else to change the tie rods geometry to account for the 6 inch lift?
May be ideal to ask the offroad forum guys for their opinions as well as to what is happening.
Old Jun 24, 2009 | 01:55 PM
skaterbro's Avatar
skaterbro
Death wobble. I fixed mine by replacing the drag link, as there was much play in it. Unbalanced tires play a huge role in the wobble too.
Old Jun 24, 2009 | 07:46 PM
highrise4x4
ok ill have to do that yea its got a longer pitman arm
Old Jun 24, 2009 | 09:00 PM
sconut1's Avatar
sconut1
When your driving it, does it feel like someone grabbed the steering wheel and just reefed on it and it returns violently?
Old Jun 24, 2009 | 09:02 PM
88f150302's Avatar
88f150302
replace the steering stabilizer the same thing happened to my friends lifted f150 he replaced the steering stabilizer and it was fine
Old Jun 24, 2009 | 11:11 PM
highrise4x4
no theres not any real vibration in the wheel
Old Jun 24, 2009 | 11:15 PM
TexasGuy001's Avatar
TexasGuy001
I would say to replace the steering stabilizer. If it doesn't have one then get one or a dual stabilizer setup.
Old Jun 24, 2009 | 11:17 PM
sconut1's Avatar
sconut1
Ok. I thought I was on to something but I'm headed in the wrong direction! Good luck with this!
