Engine Knocks Need advice!!!
Old Jun 23, 2009 | 11:59 PM
doc582000's Avatar
doc582000
Hi Guys, Yesterday got back from a trip my 5.4 in my 2004 screw starter knocking. i noticed when i was backing up in to my drive way, which sit at an angle, it incline and higher than the street like a ramp. that is when i hear it knock a little. temp was normal gas consumption was 19.2 mpg at 75 mph no wind. well all looks normal. i was using 86-87 gas. any advice, it has 67000 miles
thanks
Old Jun 24, 2009 | 09:31 AM
442w30's Avatar
442w30
What weight oil and brand of filter has/is being used? These symptoms are not new to these trucks.
Old Jun 24, 2009 | 11:57 AM
Fishin76's Avatar
Fishin76
unless you ran it out of oil, likely culprit is the cam phasers, Do you only hear it when the engines at operating temp? and below 1200 rpm's. mine does it, have no problem, just sounds like a diesel at idle.
Old Jun 24, 2009 | 06:29 PM
1saxman's Avatar
1saxman
Do you possibly mean 'spark knock'? Just wondering since you mentioned the gas. 'Pinging', if that's what you're talking about, could result from a number of causes, but you need to fix it soon as it's very destructive.
Old Jun 24, 2009 | 08:56 PM
doc582000's Avatar
doc582000
I had this truck since new. after it broke in. After first 500 miles first oil change at the dealer , after that every 3 000 miles regardless, and i have used 5-20 mobil 1 Synth. Always used synth in all my cars. last oil change went to walmart and they used castrol 5-20 synth they did not have mobil at that time. so i went ahead with castrol since i have a BMW cabrio and they recomend
castrol to their engines. what can be wrong. I talk to other people at work and said could be low octane gas. like i said i was on a trip and u never know in small towns what gas is in there. so any more ideas/
Old Jun 24, 2009 | 09:22 PM
doc582000's Avatar
doc582000
oh and about filter i guess fram. !!
Old Jun 24, 2009 | 10:39 PM
442w30's Avatar
442w30
Filter choice is more important than oil brand. The 5.4 is really sensitive to the brand of oil filter and oil weight, The opinion of most on this forum, myself included is that Fram is not the best choice for these trucks.
Old Jun 24, 2009 | 10:50 PM
doc582000's Avatar
doc582000
ok thanks! which one should i use?
Old Jun 25, 2009 | 07:23 AM
tooldad's Avatar
tooldad
What I have seen most in FTE posts is Motocraft. I personally think there are a few other good filters to use (e.g. Bosch, Mobil), but Motocraft seems to be the community consensus. Anybody else think differently? I get mine changed at the dealer so always using Motocraft. No problems at 63k miles.
Old Jun 26, 2009 | 08:45 PM
Greg B's Avatar
Greg B
Motorcraft!!! Only $4.19 at Wally World. Cheaper at some retail parts places like AutoZone and Advance Auto Parts.
alloro
Mar 10, 2017 02:51 AM
FxRiZBeAsTLy
Dec 11, 2010 10:45 AM
j.kenny
Aug 3, 2006 04:58 PM
capstan
Jul 24, 2006 10:31 AM
kdeleon
1983 - 2012 Ranger & B-Series
May 24, 2004 03:51 PM
