bw 1345 transfer case??
Old Jul 31, 2006 | 01:06 PM
j.kenny's Avatar
j.kenny
My t-case makes a knocking noise when I move the yoke back and forth. I have no experience with this, is this normal?
Old Jul 31, 2006 | 05:49 PM
andym's Avatar
andym
Doesn't sound normal. Crawl under it and see if you can figure out if the noise is internal or not. If it's internal, it's probably going to have to come out.
Old Jul 31, 2006 | 06:05 PM
j.kenny's Avatar
j.kenny
I have it sitting on my workbench I'm in the middle of a clutch job,(I keep getting rained out) the noise is definately internal. It is very pronounced when I rotate the yoke back and forth. If this is a problem should I have it rebuilt or trade it in? thanks for the reply!
Old Aug 3, 2006 | 12:10 PM
Cheggie's Avatar
Cheggie
This is a normal noise for the BW 1345 - I cracked mine open to reseal, and it's the oil pump. The oil pump is wrapped around the output shaft, and there is a fork in the case that prevents the pump from spinning on the shaft. What you're hearing is the nipple on the pump jumping back and forth between the ends of the fork. As far as I can see, this was never meant to be a "tight" fit. You'll only hear it when it's on the bench, or when you're rotating the shaft back and forth.
Old Aug 3, 2006 | 04:58 PM
j.kenny's Avatar
j.kenny
that makes me feel a little better. I was about to take it to a shop to get it checked out but I think I'll pop it back on and drive it till it breaks. thanks for the reply!
kbf1961
Jan 25, 2012 03:13 PM
gallatingator
Oct 10, 2011 01:36 PM
phillyfreak
Aug 12, 2011 11:19 PM
Help I M Stuck
Bronco II
May 28, 2008 12:56 AM
StrokeThis96
Mar 5, 2008 11:03 PM
