Little Whine?
Old Jun 23, 2009 | 09:21 AM
74baja's Avatar
74baja
Little Whine?
My truck has been whining a bit at low speeds, like coming up the hill on the dirveway (about 5-10 mph). I hope it's just a belt or something, is this something to worry about?
Thanks
Old Jun 23, 2009 | 09:30 AM
FordTruckNoob's Avatar
FordTruckNoob
Check your power steering. Be sure to use ATF to top up the reservoir, not power steering fluid. Our trucks use ATF in the power steering.
Old Jun 23, 2009 | 09:38 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I hope it is not your trans. Is there any ATF leaking anywhere?
Old Jun 27, 2009 | 11:13 AM
74baja's Avatar
74baja
Hey Rick,
Sorry for the delay. How would I know if it's the trans?
Old Jun 27, 2009 | 02:52 PM
74baja's Avatar
74baja
any ideas?
Old Jun 27, 2009 | 07:50 PM
74baja's Avatar
74baja
anyone, any thoughts?
Old Jun 28, 2009 | 09:12 PM
74baja's Avatar
74baja
One more bump
Old Jun 28, 2009 | 09:24 PM
miller_feed
Hey Jack. Sorry, been a busy weekend. Can you describe the sound a little better?
Old Jun 28, 2009 | 09:37 PM
74baja's Avatar
74baja
No problem Well, if I'm going slow, about 10 mph, especially uphill or offroad, I hear a whining sound. It's not really high-pitched, just sort of a whining that corresponds to how much I push on the pedal. If I speed up much, or slow down much, it goes away. Oh, and no ATF leak as far as I can tell.
Thanks
Old Jun 28, 2009 | 10:32 PM
cjfarm11's Avatar
cjfarm11
COuld it be your turbo? Mine started a whinning noise and my turbo ended up takin a S***
Old Jul 5, 2009 | 10:20 AM
FordTruckNoob
Thanks
Are you sure it's not your regular turbo whistle you are hearing?
