Torq Specs
Old Nov 9, 2010 | 08:22 PM
grizzly11's Avatar
grizzly11
Torq Specs
I need to know the specs on the head bolts, hydralic lifter, rocker arms, injector hold downs, and valve covers? And also head bolt sequence?
thanks
jared
Old Nov 9, 2010 | 08:28 PM
Ponyboychris's Avatar
Ponyboychris
Valve cover bolts: 8 ft-lbs.
Injector hold down bolts: 120 inch pounds
rocker arm pedestal bolts: 20 ft-lbs
Old Nov 9, 2010 | 08:45 PM
driximus's Avatar
driximus
head bolts,
Install the 18 cylinder head bolts.
Lightly lubricate the cylinder head bolt threads and flanges with clean engine oil.
Tighten the bolts in the sequence shown in three stages.
Stage 1: Using the first sequence, tighten the bolts to 88 Nm (65 lb-ft).
Stage 2: Using the first sequence, tighten the bolts to 115 Nm (85 lb-ft).
Stage 3: Using the second sequence, tighten the bolts to 129 Nm (95 lb-ft).
the Head bolts
First sequence"
13 5 4 12
17 9 1 8 16
18 10 2 7 15
14 6 3 11
second
15 16 17 18
10 11 12 13 14
5 6 7 8 9
1 2 3 4
Fuel injector hold down 120 inch lbs
Old Nov 9, 2010 | 08:46 PM
driximus's Avatar
driximus
The sequence didnt come out how I had it spaced Ill try to attach the image.
Old Nov 9, 2010 | 09:27 PM
grizzly11's Avatar
grizzly11
How are the head bolts numbered? I only have a ft/lbs wrench what sounds good on the injector hold down
Old Nov 9, 2010 | 09:33 PM
driximus's Avatar
driximus
they are numbered by tightening sequence. 120 inch lbs is 10 foot lbs. I would get an inch lbs wrench I use em for smaller measurements just to be safe.
Old Nov 9, 2010 | 10:25 PM
350long's Avatar
350long
I couldn't read the sequence in the above image, could just be my eyes, but here is a larger one. I hope this helps.
The order is the same but the specs are a little different in this image. I have seen the specs from driximus in more than one place I would use them and not the ones in this image.
eurosurplus
Jan 14, 2010 12:02 PM
6t56
401, 477, & 534 SD Engines
Oct 26, 2007 07:39 PM
Frost
Dec 17, 2005 07:37 PM
elstx
Sep 16, 2003 09:46 PM
thelonerangerxlt
1983 - 2012 Ranger & B-Series
Jun 1, 2001 11:09 PM
