.When I get everything this week, on order, I'm not sure of the torq spec's for:
IP ?
IP gear bolts: ?under outside cover and cover if torq'd
glow plugs: I think 18ft 3's ?
injectors: I think 33ft #'s ?
And what about the top of the injectors, I've never had them apart, are they torq'd
Anything else I mit of missed? Thanks for your help a head of time. Not up
on the 6.9L motors. Year 86 if it matters.
Hi: I just checked in my hanes manual,Fuel injector to cylinder head 35 ft lbs, fuel line to nozzel fittings 22 fuel line to pump 22 glow plugs 12 Injection pump drive gear cover (adapter housing)14 as for the drive gear itself I just got it tight and bumped it a littel more,could'nt find a spec on it so I just calibreated my elbow.lol
Guys thanks. I had know way to look this stuff up. I feel better knowing I have the right torq spec's. Fuel line to nozzel fitting, is that the piece on top of the injector? I guess that means the line that goes back to the pump. I'll probably see this more clearly when I take it apart..
