Oil overfill
Old Jun 21, 2009 | 11:27 PM
F250TruckR's Avatar
F250TruckR
Oil overfill
hey guys
just changed my oil yesterday, did the usual procedure and added 15 quarts of oil back into the motor as well as filling the oil filter before installing. read way over on dipstick. the guy at the ford dealer said it wasn't a big deal and it would pump it all to the top. i let it idle for a little while and it still read over so i drained probably about a quart and let it idle again and it read in the lines. checked it today before i started it and it read over, so i drained it again and now its all good. my question is, if i did run the truck probably about 40 miles with it being over on oil and if it just idled being way over, is it a big problem??? thanks a lot
Old Jun 22, 2009 | 05:46 AM
Izzy351's Avatar
Izzy351
So you put 15 quarts in the motor *AND* filled the filter with additional oil? I'm trying to figure out how you got ~2 quarts too much.
I don't think you did anything but possibly foam up the oil a bit. You should be okay.
Old Jun 22, 2009 | 07:36 AM
Kwikkordead's Avatar
Kwikkordead
I wouldn't worry about it either.
max3860
Oct 14, 2019 09:49 PM
ryansalay
Jan 10, 2018 06:55 AM
NateMack06
Modular V8 (4.6L, 5.4L)
Apr 23, 2015 06:52 AM
JustinRo2014F250
6.7L Power Stroke Diesel
15
Apr 2, 2014 08:47 PM
jgates
May 22, 2002 09:33 AM
