Shock and Strut Install - Done!
pretty easy actually
you'll need to rent a spring compressor from the parts store
tool wise, you'll need:
30mm socket
1 1/16" wrench
basic combo wrench set
vice grips
big *** hammer
spring compressor
-unbolt your sway bars
-unbolt the upper control arm ball joint from the knuckle.
-remove the 30mm nut from the lower joint on the coil-over
-unbolt the 3 nuts from the top of the coil-over
-use that big *** hammer to seperate the upper control arm from the knuckle
-lift the upper control arm up, and allow the lower control arm to fall down
-remove the lower bolt from the coil-over and lift the coil-over out
-use the spring compressor and remove the spring from the shock
-install new shock into springs
-reverse the process
I did cheat a little by pulling the struts out and actually had Sear's replace the shock in the struts. The spring compressor I borrowed from O'Reilly's was not strong enough to compress the spring or I was doing something wrong.
2004 F150 SCREW
Lariat 4X4
105K and riding smooth
The spring is a tough venture without air tools....I did mine with an air wrench it was cake....but then I helped a friend out (no air tools) and ended having to use my 3/4 drive with a 20" lead pipe to get the spring down....also helps if you have a table vice.
All in all a 30gal compressor is the best investment made so far in the garage...other than the truck that parks in it!
I'm sorry,I could not resist replying to this......but its all in fun!
No air tools - but definitely gave some ratchet wrenches a workout.
The 30 mm lower strut bolt came off pretty easily with a long heavy duty half inch socket wrench.
