Rear coil spring replacement
Old Jun 14, 2005 | 07:13 PM
exp_bill's Avatar
exp_bill
Anyone have experience in replacing a rear coil spring in an 02 Explorer 4dr?
Just replaced brakes and noticed spring cracked in second coil from the top. Looks like whole strut assembly should come out once 2 top bolts and large bottom bolt are removed but it could be tricky if the lower control arm will not drop enough.
Anyone with experience to fill me in?
Old Jun 15, 2005 | 08:26 AM
texan2004's Avatar
texan2004
Did they do away with rear leaf springs in the Explorer in 2002??
Old Jun 15, 2005 | 08:13 PM
exp_bill's Avatar
exp_bill
02 to 05 Explorers and 03 to 05 Expeditions have independent rear suspensions with upper and lower control arms and coil over shock units - quite functional actually
Old Jun 15, 2005 | 08:39 PM
texan2004's Avatar
texan2004
I looked at a newer one this afternoon after my previous post and saw that they did indeed go that route. Good move in my opinion. The rear leaf system on the older Explorers, especially the 2-doors was inadequate. Did they do something about the torison bar front suspension??
Old Jun 15, 2005 | 08:47 PM
exp_bill's Avatar
exp_bill
Replaced front torsion bars with independent coils as well in 2002 but only on 4dr. 2dr and Sport Trac retain torsion bars and leafs in rear.
Old Jun 15, 2005 | 09:58 PM
texan2004's Avatar
texan2004
errrrr!!! Too bad they didn't change them all.
Old Jun 15, 2005 | 11:42 PM
220k-f-150's Avatar
220k-f-150
I think your right on lower control arm. Need to remove pinch-bolt to wheel hub. Don't forget to disconnect any thing bolted to control arm (e-brake cable, abs wire,etc.)
Also, I think there should be 3 nuts on top.
Outlaw56
13
Feb 19, 2017 11:03 AM
chad77
Apr 5, 2016 11:49 AM
Mister_King
Mar 16, 2015 11:48 PM
dgreen
1983 - 2012 Ranger & B-Series
Mar 22, 2007 10:27 AM
