Vacuum leak
Old Jun 20, 2009 | 07:21 PM
crum71's Avatar
crum71
1/8 mile Oval Track
Vacuum leak
I know this has been discussed many times, and I was going to try and figure it out on my own. But I am out of ideas. About a week ago now, my AC stopped blowing through the vents and only on my windshield. I unhooked the vacuum line going to the 4 wheel drive,because it doesn't work. I also have a boost leak which I found out that wouldn't cause the vacuum leak. So my next question is,what do I check for? I also need to replace my 6637 in a Bad WAY. lol I went on a trip last week, pulling 3 4 wheelers and my EGT's got high on me. And today I noticed that I am only pushing 20 or so on the boost gauge.
Old Jun 20, 2009 | 08:14 PM
zx250's Avatar
zx250
Of the next Riffraff East
Unhooking the line to the hubs will create a leak unless you plug it off. Need to find that boost leak and for sure change that filter.
Old Jun 20, 2009 | 08:32 PM
crum71's Avatar
crum71
1/8 mile Oval Track
I plugged it off at the vac box. Going to order a filter Monday,should have it Tuesday. It buggs the pee out of me not knowing what to do to fix it.
Old Jun 20, 2009 | 08:35 PM
zx250's Avatar
zx250
You need to make sure you vacuum pump is working, then check the canister for cracks or holes. Next you need to check the vacuum line going to the HVAC controls. Hopefully it's not under the dash, but it could be under there as well.
Old Jun 20, 2009 | 08:39 PM
crum71's Avatar
crum71
1/8 mile Oval Track
How do I check to see if the pump itself is working? Pull a hose and see if I get suction? Its strange that it just stopped working
Old Jun 20, 2009 | 08:42 PM
zx250's Avatar
zx250
You can hear it. Key on, engine off, it should run for a few seconds to build vacuum. If it runs a lot, then you have a leak, if it don't run at all, then you have a bad fuse or pump or even a bad connection.
Old Jun 20, 2009 | 08:43 PM
crum71's Avatar
crum71
1/8 mile Oval Track
will try that tomorrow evening. thanks Barry
Old Jun 20, 2009 | 08:49 PM
zx250's Avatar
zx250
No problem, anything else electrical not working? Trying to figure out what circuit the pump is on in case it's a fuse.
Rongold
Nov 24, 2015 08:24 PM
lvin4jc
Dec 13, 2014 10:49 AM
Roasted7
Oct 21, 2012 06:04 PM
jamesj
May 16, 2005 09:45 PM
