Head gaskets???????
Old Jun 20, 2009 | 12:54 PM
KINGRANCH82's Avatar
KINGRANCH82
Head gaskets???????
Hey guys just curious as to how many people have had hg's replaced more than once?????? If they replace em once is it a good chance that it will happen again?? Just curious cuz the warranty is up in nov 09 and i dont wanna be stuck flipping that bill. Thinking about getting a new 150 instead. Any help would be appreciated. Thanks
Old Jun 20, 2009 | 01:10 PM
rollerstud98's Avatar
rollerstud98
There is a possibility it will happen again, but if they correct the problem that cause the heads to lift and pop the gaskets then you should be pretty good. My 03 has not had any head gasket problems yet thankfully. One of the main causes for the head gaskets to go is over boosting from stuck turbos, good diesel tech will fix the turbo as well as the gaskets while in there, not so good techs will just redo the gaskets, possibly not even check the heads for flatness which once the gaskets are popped the heads are usually warped and then even with studs in you are almost certain to pop again. Nice flat heads and headstuds installed if you are just running stock tuning you should be pretty much bullet proof for the hg's, egr cooler is another story though.
Old Jun 20, 2009 | 01:16 PM
KINGRANCH82
Doesn't the egr cooler usually go out shortly after hg's are replaced. I thought i read that on here but could be wrong.
Old Jun 20, 2009 | 01:32 PM
brickie's Avatar
brickie
The blown HGs pressurize the coolant system beyond its design so the EGR cooler could be weakened by the excess pressure.It is prudent but not nessary to replace the cooler if the HGs are blown.
hodges710
Jul 18, 2012 08:04 PM
AFoster1025
Dec 1, 2010 12:38 AM
crazer42
Mar 21, 2010 01:01 PM
Rushmore X
Sep 20, 2008 08:02 PM
dassmoof
Nov 13, 2003 08:28 PM
