smog pump
Old Jun 23, 2009 | 12:35 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
The point is, hydroboost brakes don't use vacuum, therefore very little vacuum is needed.
-Enjoy
fh : )_~
Old Jun 23, 2009 | 02:16 AM
LCAM-01XA's Avatar
LCAM-01XA
Well yah, but if he wants an electric vacuum pump that can run vacuum brakes...
Old Jun 23, 2009 | 08:36 AM
84 f250 6.9's Avatar
84 f250 6.9
Originally Posted by Dave Sponaugle
Since I did my hydraboost brake conversion my vacuum pump is on the way out again.
Defrost only untill the pump warms up and starts making vacuum again.
Given the cost of a vacuum pump, I can live with defrost only, that is where it usually is anyway until I reach operating temp in the winter.
would a bad vacuum pump be y my ac and heater doesnt work and it just rolls HOT air slowly out all vents (ALL YEAR LONG!!!) im real curious bout that
Old Jun 23, 2009 | 11:14 PM
LCAM-01XA's Avatar
LCAM-01XA
How are your brakes man? If the brake assist feels good then vacuum pump should not be on your suspects list. I'm thinking more likely tis a vacuum leak in the vent selector head behind the dash, the one that's operated by the levers you slide left-right.
Old Jun 23, 2009 | 11:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
On the early model trucks the coolant circulates through the heater core constantly if the engine is running.
So a bad seal on one of the heater doors, or the door being out of adjustment could be your problem.
For about 20 years I have been meaning to put a manual valve on mine to stop the coolant in the summer, but it still is not done.
Old Jun 24, 2009 | 12:26 AM
LCAM-01XA's Avatar
LCAM-01XA
I have a valve from a Ranger, tis vacuum controlled and I have it T-eed with the recirculating door servo - that one gets vacuum only when the HVAC is set to "off" or "max A/C", so in those two positions I have very little flow through the heater core.
Old Jun 24, 2009 | 12:52 AM
David85's Avatar
David85
Been meaning to do a mod like that since I first heard about it. Never gets done because I don't have the time for much tinkering anymore. This weekend is booked for some F350 rear springs if all goes well and work weeks are getting longer. I guess since I'll be at the wreckers anyway, I'll try and remember to look for that valve if there is a ranger or exploder thats new enough.
I noticed the air intake for the climate control when set to max is actually between the kick panel and the heater core housing. I know the ABS plastic housing is a decent insulator, but there has to be some heating going on there as the air goes past the heater core housing on its way to the evaporator core.
I measured a 4 degree celcius difference between the dryer under the hood in the engine bay and the air vents in the truck. That is a difference that you do notice on hotter days.
Bmbiehler
Jun 27, 2010 11:43 PM
Jrock909
Mar 8, 2007 07:28 AM
JBronco
1978 - 1996 Big Bronco
Dec 2, 2002 05:34 PM
truckfreak69
Oct 26, 2002 12:24 AM
