smog pump
Old Jun 20, 2009 | 10:31 AM
bigb9582's Avatar
bigb9582
smog pump
hey guys i own a 86 f250 6.9. i was wondering if the smog pump on it is needed?? is there any benifit to unhooking it??
Old Jun 20, 2009 | 12:01 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Smog pump on a 6.9 ... There is no smog pump on a 6.9!
What you are likely talking about is the vacuum pump and you do need that if you want the heater and things to work that require vacuum.
-Enjoy
fh : )_~
Old Jun 20, 2009 | 02:51 PM
87crewdually's Avatar
87crewdually
Main function for the vacuum pump also are for the power booster for your brakes!
Old Jun 20, 2009 | 07:47 PM
kenpobuck's Avatar
kenpobuck
Oh yea, believe me you need that booster LOL!! Real hard to stop comimg down the hill to my place with something this heavy.
Old Jun 21, 2009 | 12:15 AM
bigb9582's Avatar
bigb9582
ooo so it is a vac. pump. i thought it was a smog pump of some sort for the diesel. or some emision thing
since i know its the vac pump, ill leave it alone.
thanx for the info
Old Jun 21, 2009 | 01:53 AM
LCAM-01XA's Avatar
LCAM-01XA
Convert brakes to hydroboost, ditch the C6 trans for a bolt-action, install a PSD vacuum pump or entirely convert your HVAC to cable controls of a non-A/C truck - only then you can lose the vacuum pump.
Old Jun 21, 2009 | 01:03 PM
Festus Hagen
Methanoholic
Why install a PSD vacuum pump??
-Enjoy
fh : )_~
Old Jun 21, 2009 | 03:36 PM
farmert's Avatar
farmert
The super duty trucks have an electric vac. pump.
Old Jun 21, 2009 | 04:14 PM
Festus Hagen
Methanoholic
Aw, Didn't know that, thanks!
-Enjoy
fh : )_~
Old Jun 21, 2009 | 08:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Since I did my hydraboost brake conversion my vacuum pump is on the way out again.
Defrost only untill the pump warms up and starts making vacuum again.
Given the cost of a vacuum pump, I can live with defrost only, that is where it usually is anyway until I reach operating temp in the winter.
Old Jun 21, 2009 | 08:38 PM
AndysFords's Avatar
AndysFords
I remember reading about some guys that were putting 4 cyl tractor engines in 1/2 ton Fords, they found a 12 volt vacuum pump in the Grainger book that would supply their brake booster.
Old Jun 21, 2009 | 10:10 PM
Festus Hagen
Methanoholic
How about a Super Duty electric vacuum pump, for the basic control needs I think that would be an awesome conversion.
Or as already suggested an industrial 12v type.
-Enjoy
fh : )_~
Old Jun 22, 2009 | 02:05 AM
LCAM-01XA's Avatar
LCAM-01XA
Yep, hydroboosted trucks with hand-shakers or E4ODs can use the PSD or another electric pump. Trucks with the C6 trans may however burn up an electric pump as them need constant vacuum supplied to the line pressure modulator on the trans, which would likely cause the electric vacuum pump to run all the time.
Dave, my old vacuum pump was on its way too, I found out that if I revv up the engine to 2k or so and keep it there for a minute the pump will build up enough vacuum for the HVAC to operate properly.
Old Jun 22, 2009 | 02:30 AM
David85's Avatar
David85
I once asked the question about the electric superduty vacuum pump as a replacement for a regular brake boost vacuum pump and the consensus was it doesn't pull a hard enough vacuum nor does it have enough CFM to be safe.
That reminds me though. I need to check the vacuum in my truck as the brakes seemed a little weak lately.
Old Jun 23, 2009 | 12:19 AM
LCAM-01XA's Avatar
LCAM-01XA
David, this is correct, the PSD pump is pretty weak, and it can't operate power brakes. Look for one off a school bus tho, as many of those had an electric vacuum pump as a backup for the main engine-driven one.
