Oh noooo!!!!!!!!!!!!!!!!!!!!!
Old Jun 19, 2009 | 04:06 PM
Fordz-r-us's Avatar
Fordz-r-us
Just a thought here, but could the ceramic have been chipped by Ford when they assembled the engine? These motors get thrown together pretty fast and a busted plug could have been slipped in there without notice. I'm sure a missing piece of ceramic like that wouldn't affect how it performed so you'd never know. Did you hear it crunch when you loosened it? Is the broken section clean like a fresh break?
Old Jun 19, 2009 | 04:31 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Originally Posted by Ryan50hrl
Get a shop vac and tubing and get that down into the cylinder...use very small tubing so you know when it gets that piece sucked up ....clean out the cylinder and reassemble...
X2
But before you do anything else, just spend a $1 or $2 and try the mirror trick. It could just be sitting there
Vacuum is your best bet though
Old Jun 19, 2009 | 05:31 PM
NASSTY's Avatar
NASSTY
GwarForAll1021 what kind of spark plugs are you replacing the originals with?Champion 1 piece or stock ones?
Old Jun 19, 2009 | 06:15 PM
GwarForAll1021's Avatar
GwarForAll1021
well i put it all together and fired it up and it sounded like a champ!
till i noticed i can hear the peice of porclin banging around in my cylinder hahaha
i guess im going to pull that plug and hope it blows it out of the hole...
Old Jun 19, 2009 | 06:23 PM
bridge's Avatar
bridge
Sick 'n Tired
Seriously, can you really hear it? If you can its probably already etched the hell out of the cylinder wall.
Old Jun 19, 2009 | 06:27 PM
GwarForAll1021
yup your probably right. its a risk i was willing to take. i couldnt get it and i cant afford to pull my heads. i had no choice...
Old Jun 19, 2009 | 06:37 PM
bridge's Avatar
bridge
Sick 'n Tired
It will eventually breakup and make its way to your catalytic converter. You might want to check compression on that cylinder on a regular basis.
Old Jun 19, 2009 | 06:44 PM
GwarForAll1021
why? theres not much i can do...
Old Jun 19, 2009 | 08:10 PM
Ryan50hrl's Avatar
Ryan50hrl
Seriously.....pull the plug....get a vacum.....any one either a shop or a home one....go to a farm store and buy a chunk of small like 3/8 tubing and tape it to the vac hose.....stick that down into the cylinder through the spark plug hole and get any small pieces out.........like a 5 dollar fix at worst
Old Jun 19, 2009 | 08:20 PM
NASSTY's Avatar
NASSTY
In another thread he said he got it out.
Jeeze, it gets kind of confusing when he's got 4 threads going about a spark plug change.
Stephen67
27
Nov 3, 2011 10:17 AM
Krisx125
69
Apr 20, 2011 09:11 PM
rnelson1986
Mar 17, 2010 12:53 PM
427 fordman
36
Jan 20, 2010 04:06 PM
Jbrown8988
36
Apr 16, 2009 11:40 PM
