305/35/24thats the tire size.or i was thinking about 22 inch with 305/40/22
is 4wd .what off set should it be .do i have to lift the truck to get them fit? thanks for the info
Here's a great tire size calculator! Try and keep the total wheel size below 33 to avoid a lift. Both those sizes appear to be below 32" so you should be good.
a 305/40/22 looks to be about 31.5" tall so no trouble on the diameter at least. the 305/35/24 should still be under 33" so also no lift needed.
You may need a little more backspacing than stock though for the wider tire. I know a 285 clears no problem so maybe 1" more backspace?
There are folks on here that run 305 and 315s so they might be able to tell you what backspace they run.
or your local rim shop will be able to tell you as well... Any metropolitan area rim shop will match most internet prices and although you have to pay tax, you save on the shipping
