Overhead consol reading CAL
Old May 12, 2009 | 09:30 PM
chazman's Avatar
chazman
My overhead consol is reading Cal with a little square box above it. How do I calibrate it to get the direction back ?
Old May 12, 2009 | 09:53 PM
BAJI26's Avatar
BAJI26
Try pressing and hold the two button for a few seconds.
Old May 12, 2009 | 10:29 PM
mlshelton's Avatar
mlshelton
Mine doesn't illuminate / display anymore unless I smack it a couple times - is that just a loose wire or ground or something?
Old May 12, 2009 | 11:33 PM
soutthpaw's Avatar
soutthpaw
drive in a slow circle several times. CAL is for calibrating the on board compass so it knows which way its going...
Old May 13, 2009 | 11:06 AM
Capt Dan's Avatar
Capt Dan
loose diode or chip. There is some info on here about how to fix it. Very common.
here it is...
https://www.ford-trucks.com/forums/4...-gone-out.html
Old May 13, 2009 | 12:10 PM
howler4x4's Avatar
howler4x4
The technical term is 'percussive maintenance'
Old May 13, 2009 | 07:01 PM
chazman's Avatar
chazman
Circling the wagon did not work. I even went in the opposite direction. Now what???
Old May 14, 2009 | 06:19 AM
rich250's Avatar
rich250
this is from the manual
1-For optimum calibration, turn off all non-essential electrical accessories (rear window defrost, heater/air conditioning, map lamps, wipers, etc.) and make sure all doors are shut.
2-Drive to an open, level area away from large metallic objects or structures and high voltage lines.
3-Press both buttons for 6 to 8 seconds until CAL is displayed.
4-Release both buttons and drive slowly in a circle until CAL disappears from the display (about 2 to 3 circles).
The compass is now calibrated.
Old May 14, 2009 | 10:26 AM
chazman's Avatar
chazman
It fixed its self this AM when Istarted it. But maybe it was just dizzy from going in circles. Thanks guys........
Old May 14, 2009 | 04:13 PM
chazman's Avatar
chazman
I suppose that it did not fix its self. I had to run the circles again. But when I held the buttons in for 8 count ZONE came up. I don't know whatZONE Pittsburgh PA is. So I just punched in ZONE 12.. Shut the EX off and restarted and the direction came up on the readout. Is there always a box around the direction? If I am in the wrong ZONE could someone who has a book tell me the right one. Thanks
Old May 14, 2009 | 07:23 PM
WJC's Avatar
WJC
What zone is new jersey? I was trying to reset the mpg's the other day and zone came up, was not sure what to set it to.
Old May 14, 2009 | 08:10 PM
rich250's Avatar
rich250
from factory the zone setting is 8,if I'm reading the half **** map right PA. and New Jersey should be zone 10
Old May 14, 2009 | 08:48 PM
chazman's Avatar
chazman
I think that mine is set to Zone 12 but If it's like avaition thats only a few degrees off. Probably sets on magnetic north.I think PA are like 7 degrees off magnetic north.Its close enough,cause the GPS switches direction at the same time. But I'll set it to 8 in the morning. Thanks guys
Old May 16, 2009 | 03:31 PM
chazman's Avatar
chazman
well it resets itself to 8. I had a blank square there this AM.
Circled it and then shut it off .Restart showed correct direction. Hmmmmmm????
Old May 23, 2009 | 09:55 AM
chazman's Avatar
chazman
Keeps resetting itself to a square. But some days it has a direction on it. Sounds like it needs some help. Any ideas ?????????
