sd ac not cooling correctly
Old Jun 18, 2009 | 07:59 PM
gbishop's Avatar
gbishop
"03" f250 cooling to 70f at best checked pressure low side was 55psi highside was 225psi started to charge today low side was 75psi and high is 350psi system was equaling yesterday when ac was shut off truck has 162,000 thanks for any help
Old Jun 18, 2009 | 08:23 PM
projectSHO89's Avatar
projectSHO89
Seriously, take it to someone who knows what they are doing before you hurt yourself.
Your system is now way overcharged. You'll be lucky if something doesn't blow.
Old Jun 19, 2009 | 01:04 PM
gbishop's Avatar
gbishop
never hooked up charge can just the guages,and i know not to charge on high side!
Old Jun 19, 2009 | 03:12 PM
lsrx101's Avatar
lsrx101
Mist water from your garden hose over the condenser, If the high side drops like a rock, replace the clutch fan and clean the radiator/condenser.
Both pressures are way too high. This usually indicates a condenser airflow issue.
EconolineFan
Jul 23, 2011 07:53 AM
tp4pdb
Aug 17, 2008 10:36 PM
crewsn
Aug 15, 2007 06:15 AM
jared66
Jun 25, 2007 11:18 PM
Saxon
May 3, 2007 09:05 AM
