1978 - 1996 Big Bronco
Complete Overhaul
Old Jun 18, 2009 | 02:36 PM
mlgodwinone's Avatar
mlgodwinone
Question Complete Overhaul
How much do you guys think it would cost to overhaul my Bronco?
92 XLT 5.8 351 Windsor
Im talking motor, tranny, rearend, everything.
Leave stock except a minor lift and tires.
Im in need of it I got almost 270,000 miles and everything is still stock.
Its a Daily Driver but close (within 30 Miles round trip)
Thanks for any imputs
Old Jun 18, 2009 | 02:42 PM
andym's Avatar
andym
Are you going to do the work yourself or are you going to pay someone to do it? Rebuilding the whole drivetrain is expensive. If you really went nuts on it and replaced or rebuilt every "wear" component it would cost thousands and thousands.
Old Jun 18, 2009 | 02:51 PM
mlgodwinone
I will do what I can but im not a mechanic by no means everything else will have to go to a shop to have done.
Yea im looking at the major stuff to replace before it gives out.
Motor and Tranny etc but whatever else will need replacing.
Or will I just be better off getting another bronco with alot less miles?
I have a little less than 5k and I cant afford to get a truck to make payments.
Thats what im asking for.
But I aint gittin rid her of cuz one day I might have enough money to fix er up.
Old Jun 18, 2009 | 02:55 PM
andym's Avatar
andym
If you can't do all the work by yourself, you are looking at WAY more than $5k to rebuild the engine, tranny, transfer case, and rearend. At least double that, probably not more than triple though.
The tranny is going to be $3k by itself.
Seriously though - why would you want to rebuild it if it's working fine? Keep driving it, save your money, and buy something else when the one you have is worn out.
Old Jun 18, 2009 | 03:13 PM
mlgodwinone
Thumbs up
Okay thanks for the Input. You Guys always have good advice.
I had no idea it cost quite that much.
Yea its runnin great but every one keeps tellin me I need to do somethin before it craps out on me. I would like to have another bronco but every one I look at is in about the same shape (miles) and I dont want another brand (ford Is to Good to Me)
How long do the 351 windsors usually last anyway, 270,000 is alot. And Ive put about 2000 on it in the last 3 months...
Thanks again andym
I appreciate the input.
Old Jun 18, 2009 | 04:32 PM
Kemicalburns's Avatar
Kemicalburns
motor life span depends on so many different factors i dont think you can estimate that. some die sooner then others.
if your worried about it, get a wreckingyard 5.8 thats complete. get an engine stand and start tearing it down and get it rebuilt and have it ready so when this motor craps you can swap motor for motor.
as for the tranny keeping up on the fluid/filter changes is important, you could probably do the same with a wrecking yard tranny and have it rebuilt when money and time provide and wait or swap out at your lesure.
Old Jun 18, 2009 | 08:01 PM
ottawaguy's Avatar
ottawaguy
Ditto that...
Too many variable and unknowns to predict how long your engine will last. Do a compression check on the engine, change fluids in engine, tranny, dif. Don't forget to check for signs of wear when changing fluids.
Other than that, if all is well then live and let live.
I have just recently aquired a 94 xlt in good condition, but the braking system has been let go, so it will be completely replaced. I am slowly and methodically going over it and replacing anything that even looks questionable.
There is no shortage of things to spend our hard earned bucks on....save it for an upgrade or a new set up fuzzy dice.
I would do the same really, if I were you. You obviously want a mechanically top notch truck, so start with the visibly worn parts and then upgrade as you see fit.
All the best with your Bronco!
charger6t9r
Sep 17, 2013 08:26 PM
fatherdano
May 24, 2010 08:25 PM
smbikes
Feb 1, 2009 07:25 PM
youkonbob
Aug 30, 2002 03:40 PM
bigred
Nov 26, 1999 04:10 PM
