fuel pump number
Old Jun 18, 2009 | 01:57 PM
zenmaster's Avatar
zenmaster
fuel pump number
Hey folks,
I need the ford number for this fuel pump. This is either a 240 or 300 straight 6, mid 60's . I'm hoping Ford used the same pump on these engines. The pump diaphragm is pooched. The filter is on top of the pump as you can see. The mounting bolts are at 3 and 9 o'clock. Here is a pic:
Anyone know the Ford number? If more info is needed, just let me know.
Thanks for all your help,
John
Old Jun 19, 2009 | 11:47 AM
Freightrain's Avatar
Freightrain
Where's Bill? He can spit numbers out easily.
Strange how that pump looks just like a 302 pump, just upside down.
Old Jun 19, 2009 | 04:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Why oh why couldn't you have had an FE engine? There are only two 1965/76.
Instead, you want one for a 240/300.
1965/79 F100/350 or Econoline: There are four, which replaced nine others.
C3AZ9350Y .. Fuel Pump 240/300 / 1965/72.
ID Number: 0178 / 0227 / 0484 / 0485 / 3913 / 3938
D5UZ9350C .. Fuel Pump 240 / 1965/72
ID Number: 0290 / 0483 / 4092
D3TZ9350A .. Fuel Pump 240/300 / 1970/77.
ID Number: 4532 / 6399-S
D9TZ9350D .. Fuel Pump 240/300 / 1970/79.
ID Number: 4900-S / 6295-S.
If none of these ID numbers match what you have, which wouldn't surprise me in the slightest, since I only looked at E & F100/350's (F500/750's are different), post what you find.
Old Jun 19, 2009 | 05:34 PM
zenmaster's Avatar
zenmaster
Thanks Bill,
Here's what I found:
Left mounting flange 31G4
Right mounting flange 3912 S
Lower pump body 0-1720
No other numbers on pump
Pics:
Thanks for all your help!
John
Old Jun 19, 2009 | 08:40 PM
garbz2's Avatar
garbz2
There are millions of them available at any parts house. With filter or without. The 300 was around in this form until 85....
Here is a replacement carter with the filter the right way on the bottom.
While we find your parts, please enter your ZIP Code at CSK Auto
Here is a Bosch upside down unit.
Garbz
garbz2's Avatar
garbz2
Garbz
Old Jun 20, 2009 | 05:11 AM
NumberDummy
Originally Posted by zenmaster
Here's what I found: Right mounting flange 3912 S
C3OZ9350D .. Fuel Pump / Marked: 3912-S / Obsolete
Original application: 1965/66 E100 170 & 240 I-6.
GREEN SALES CO. in Cincinnati OH has ONE: 800-543-4959.
Old Jun 20, 2009 | 12:29 PM
zenmaster's Avatar
zenmaster
Bill,
Thanks for taking the time! I'm working on keeping this as stock as possible. I really appreciate all your help, in fact I couldn't have found it without you. I'll give Green Sales a call and see if they still have it. Btw, if they don't, could I use one of the other numbers you listed above?
You're the best,
John
Old Jun 20, 2009 | 12:48 PM
zenmaster's Avatar
zenmaster
Garbz2,
Thanks for the reply. I would like to get the Motorcraft OEM if possible. Aftermarket is my second choice. I'd like to keep this as stock as possible. It may cost more, but it's correct. I always try to buy American first.
Thanks,
John
zenmaster's Avatar
zenmaster
Garbz2,
Thanks,
John
