park brake
Old Jun 18, 2009 | 08:37 AM
deezel's Avatar
deezel
park brake
doing brakes on 05 f-150 .rear rotors came off hard .tapprd on actuator lever for parking brake and got rotor off.need to find out if p. brake hanging is common and what the fix is.thanks for any replies in advance.
Old Jun 18, 2009 | 09:36 AM
Ryan50hrl's Avatar
Ryan50hrl
parking brakes hanging up was an issue early on.....there i believe was a tsb on it....check the tsb link above
Old Jun 18, 2009 | 10:12 AM
deezel's Avatar
deezel
having problems pulling up full text tsb.
Old Dec 9, 2009 | 11:43 AM
Sputz's Avatar
Sputz
I'm also having issues with the parking brake dragging and would like to see the TSB - it is listed in the summary as Bulletin # 08-14-18 but is not shown in the "full text" section - the NHTSA # is 10024843 but they want $45 + for the info....
2004 F-150 Lariat S-cab
Old Jan 9, 2010 | 11:24 AM
Sputz's Avatar
Sputz
Parking Brake dragging?
Well, I had the local tire store inspect and $100+ later the vibrations are pretty much gone but the rear brakes still squeal when backing out of the drive-way and still cold - there was wear on the parking brake drums even though replaced 15,000 miles ago and have not used the parking brake - any suggestion short of taking to the dealer?
Old Jan 10, 2010 | 11:47 AM
MisterDave2's Avatar
MisterDave2
I have a whole pain in the pants going on with my pass. rear park brake. Tommorow will be 3rd trip to dealer, it's under warranty and they told me there's a TSB. They already replaced the cables and lever so maybe you might want to check if it's under a safety warranty.
Old Mar 27, 2010 | 09:44 PM
schmaux72's Avatar
schmaux72
My 2005 F150 Supercrew (9500 km on the clock) started to shimmy yesterday so I checked all the tires, torqued all the lug nuts, and basically didn't see anything wrong.
Drove it around the block today, put the window down, and heard bad noises from the right rear wheel. The parking brake was released but the "drum" inside the rotor was hot to the touch and apparently dragging very badly. Guess I'll have to see if my outrageously priced extended warranty covers that one. It seem to be an issue with these trucks.
Roy in cold, snowy Alberta
Old Mar 30, 2010 | 04:45 PM
schmaux72's Avatar
schmaux72
Oops, that shuld have been the left side brake that was stuck on.
I took the truck to the local Ford dealer and there is a tsb on the parking brake not going off problem.
TSB 08-11-1:
The fix: Replace both park brake levers and the L/H park brake table per the tsb.
Extended warranty covered it but $100.00 deductible had to be paid.
Old Jun 2, 2010 | 12:33 PM
Sputz's Avatar
Sputz
The dealer replaced the e-brake cable and actuators on my '04 - I still get a loud squeak in reverse when brakes are applied and still cold - then goes away. The dealer has no explanation or fix - I guess my neighbors will just have to put up with it every morning until it's time to trade....
Old Jun 2, 2010 | 12:40 PM
ChargersFanInCO's Avatar
ChargersFanInCO
The 2008 I had did it, too. Cable released, but the mechanism stuck. Learned to jam the pedal as far as it would go, and then pop the handle to make it release.
Doc
2009 - 2014 F150
Jan 5, 2018 01:24 PM
ChalmersP
Jun 3, 2017 09:00 PM
autochefc
Sep 10, 2012 04:54 PM
choochoof150
2004 - 2008 F150
Jan 1, 2011 03:30 PM
ktm520mxc
Feb 5, 2010 08:00 AM
