Dual A/C problem
Old Jun 17, 2009 | 08:15 PM
hang10's Avatar
hang10
Dual A/C problem
03 Mountaineer. With A/C on, dual on or off, with auto on also. Get A/C out of the passenger vents only. Heat out of the drivers side and rear vents. Need ideas where to look. Blend door actuator possibly? bad switch? Broken door? Any ideas appreciated.
Old Jun 25, 2009 | 08:15 PM
muddingmcdude's Avatar
muddingmcdude
i have the exact same problem with my explorer ? someone have any idea?
Old Jun 25, 2009 | 09:50 PM
shorod's Avatar
shorod
Have you tried running the self diagnostics on the DATC? It may point to an issue. Or, it may do like the one in my wife's Lincoln LS and give no codes. However, with my scan tool connected, I was able to monitor the temp sensors and determined that driver's evaporator air discharge temp sensor was railed causing the system to continuously attempt to run hotter air out the driver's side. A $21 sensor later and everything was working correctly again.
I don't think the Mountaineer and Explorer use a Dual Coolant Control Valve (DCCV) like the LS. If it does, I'd start by pinching off the driver's side heater hose and see if that makes a difference.
-Rod
Old Jul 28, 2009 | 10:42 AM
osheam's Avatar
osheam
Similar Problem
AC blockage Ford Explorer 2003 equipped with DEATC & rear AC controls: I am having a similar problem, AC works fine for about one hour, then very little air is blown through the vents, even though the fan is fully engaged. After sitting for a while, the blockage is cleared (I am assuming that the evaporator is icing up) and the AC works fine. AC coolant pressure is within the acceptable limits. Any ideas?
Old Jul 29, 2009 | 07:54 PM
dave_s's Avatar
dave_s
05 aviator with the same problem!!! dual temp controls passenger side makes it to cool
driver's side gets hot. Will turn up hotter but won't cool, a/c system charged and working
but was un able to locate the actuator for the blend air door( all th posting I believe were
about single controller) help!!!
Old Jul 30, 2009 | 09:32 AM
osheam's Avatar
osheam
Hey Dave: I also have the dual controller and the lower vent air is much cooler on the passenger's side than the driver's side. Did you try the to read the codes from your controller (press off and lower vent buttons, followed by the auto button)?
Old Jul 30, 2009 | 10:13 AM
osheam's Avatar
osheam
Where is the driver's and the passenger's evaporator air discharge temp sensors located? Thx.
1993 ford
Sep 7, 2017 09:26 AM
WI Camper
May 30, 2017 11:51 AM
muneeb
Apr 25, 2016 07:45 AM
RMeans
Apr 21, 2016 08:36 PM
pete315
Jun 8, 2010 07:42 AM
