Yep sure r. Got myself a 6.75 hp 2,800 psi pressure washer for free. the first time it was used the oil drain plug fell out n locked up the motor so I have some work to do before I can use it.
howdy ND. was screwin around the other day and found a little hole. small enough that the front and back tires couldnt go in at the same time. but it was DEEP. despite my amazin approach angle provided by my homemade bumper, it still hit the ground, and there are very deep gashes in the ground from my muffler and front, rear spring mounts. thank God for factory steel skid plates!
