Sponsored by: Auxito
Radio
Old Jun 17, 2009 | 06:28 PM
1986fordrangerman's Avatar
1986fordrangerman
Radio
Will a 98 Ranger CD player work in a 97 F150? I have been wanting to put a cd player in my truck because mine just has a cassestte and I happen to come across a 98 Ranger that has one. They both look the same from the outside but are they much different with the plug in's. Thanks
Old Jun 17, 2009 | 10:19 PM
papajoemrt's Avatar
papajoemrt
if the outsides look the same i'm guessing they are the same on the outside. I took my brother's cd player out of his 99' SD and it will fit directly into my 02' 150 wiring and all.
Old Jun 17, 2009 | 10:49 PM
galaxie641's Avatar
galaxie641
There is a mounting bracket that hangs down on the cassette players, if you put a 6 disc in you have to remove the bracket. I assume a single will also require it to be removed. The plugs were changed in '99 in the F150's, not sure when in the Rangers.
dizzydean
Dec 16, 2003 01:51 PM
stemen_a
Sep 29, 2003 07:49 PM
fordlvr25
1983 - 2012 Ranger & B-Series
Jan 13, 2003 03:20 PM
jpruett1
Nov 17, 2000 08:20 AM
