Problem with installing after market brake control
Old Jun 17, 2009 | 08:41 AM
F150XL's Avatar
F150XL
I tried to hook up my brake control a few days before i went on a camping trip and found out it did not work do to ford not hooking up the wire harness corretly. Ford never installed a fuse for the hot wire and there was no brake signal coming from the wire harness. Had to take to a rv dealer to have it done like i hade never had any wires at all. trying to get ford to pay me back will find out in a couple of days. My ford did come with the tow package.
Old Jun 17, 2009 | 10:33 AM
Bsimmer3000's Avatar
Bsimmer3000
Sounds like your RV place ripped you off like the one near me tryed to do. I wanted a hot wire to charge my trailer battery and they said that the system on my truck didnt allow that and they would have to install a whole new 7 pin wireing harness but i already had the tow pack. Well i come on here and someone confirmed that all i needed to do was install the relay and fuse that was in the glove box and it would function just fine and it did. Take a look in your glove box for a bag with a harness, relay and some other bits. The parts you needed were in there.
Old Jun 17, 2009 | 10:36 AM
442w30's Avatar
442w30
Dont know about the 09's but my experience with my 96 98 2000 2001 2003 2005 2008 was to hook up the factory supplied brake controller harness and install a fuse to complete the circuit. Everything was always in my glove box usually took about 5 min to complete and your good to go. Maybe the 09's are different.
Old Jun 17, 2009 | 11:27 AM
F150XL's Avatar
F150XL
I got everything from what was in the glove box, and installed the relays i was still not getting any power to the brake control and still had not brake signal from the pigtale. The manual said there should be a fuse under the hood at spot 17 but there was no fuse or wireing for that spot. Have a "09" . All he hade to do is get a hot wire then patch into other wire from under the dash. It works great, and had three rv deales look at it and they said the same thing. I think thay just forgot to connect it at the factory.
Old Jun 17, 2009 | 11:32 AM
F150XL's Avatar
F150XL
I think Ford must have forgot to hook it up at the factory. Did all that that was in the glove box and still did not work. Had three rv dealers check it and they all said the same thing that i was getting no power or brake signal either. Looked in the owners manual and said there should be a fuse in the 17 spot but there was no fuse or wiring for it.
Old Jun 17, 2009 | 12:38 PM
F150XL's Avatar
F150XL
Just found out by FORD that when they say tow pakage they mean everything but the wiring for the brake control if you have a truck with the 4.6 2v engine and the 4x2. thats a kick in the *****!!!!!!
Old Jun 17, 2009 | 01:11 PM
Bsimmer3000
Thats strange. As the trailer tow pack includes a 7 pin harness. Why would they supply it and not connect it?
Old Jun 17, 2009 | 10:50 PM
F150XL's Avatar
F150XL
I'm going back to the ford dealer where i got it and, 1 see way it was not hooked up and2 way did they not tell me that at the time of my purchase. Says nothing on the window price sticker about not being wired fore a brake control. If you have a tow pakage you should have a brake control wired up.
Old Jun 18, 2009 | 08:03 AM
Bsimmer3000
I still think your RV place's tryed to do the same as the RV place i went to to be honest. Im not certain but if you can have the Ford TBC on the XL then im almost certain you will have wireing from the front of the truck to the 7 pin harness at the rear. There's no reason why they wouldnt have had that wired up and if they didnt you should have got them to sort it out. So just to get this straight. You connected your brake controller into the wireing harness where the factory TBC normally goes and you connected the relay and the fuse and you still have no power to your brakes and 12v power?
Old Jun 18, 2009 | 08:29 AM
F150XL's Avatar
F150XL
Ford gave me the manufacturing report of what is all on my truck and it stated there is no wiring for a brake control for this truck, but i have there seven wire plug on the back of it. The fuses i put in is for charging the rv battery. They gave me two fuses "relays". Did you have to put a fuse in the #17 spot in the fuse box under ther hood?
Old Jun 18, 2009 | 01:50 PM
ADCO's Avatar
ADCO
Mine has the fuse in the #17 slot, however I have the 4.6 3 valve engine.
Old Jul 10, 2009 | 12:56 PM
daveinhanford's Avatar
daveinhanford
trailer brake control
fyi, went to ford and saw the service bulletin 20706. It states all 4.6linter 2 v engine equiped trucks built after 12/01/2008 except equipped with fog lights are not wired for power to a brake controler. Crap
Dave
metriccar
Apr 25, 2012 11:05 PM
DieselBeast01
2004 - 2008 F150
Jan 27, 2012 06:47 AM
drumfield
Electrical Systems/Wiring
Sep 3, 2011 07:44 PM
Frankievespa
Apr 11, 2011 09:56 PM
mike360
Apr 28, 2004 06:18 PM
