Flame Thrower!
Old Jun 16, 2009 | 09:37 PM
suff1cate's Avatar
suff1cate
Unhappy Flame Thrower!
My other thread is dying so I decided to start a new one with a new problem. In case you don't know, I have a 83 F250 with a 460.
My engine is backfiring bad. Whenever I drive down the road, I can hear it backfiring from in the cab. It's not so bad that it sounds like a shotgun, but it's throwing smoke everywhere. I changed the spark plugs, cap, rotor, and wires the other day and I put them just like they were. Today I messed with the idle screw and also sprayed carb cleaner in the carb while my wife gave it a little gas. Whenever I push in the gas while in park, if I rev the engine to high rpm, it will shoot a flame out of the pipes. My wife followed me while I was driving the other day and she said whenever I would push in the gas it would flame up in the exhaust and when I would let off the gas it would do it too.
What are my options here? Please be as descriptive as you can because I'm far from an expert. After I get this fixed, my truck should be running perfect. Thanks guys.
Old Jun 16, 2009 | 09:52 PM
bill11012's Avatar
bill11012
Modular motor junkie
my 460 does that, I rebuilt the carb and it did not fix it but it helped. You should try that.
Then make sure the timing is right.
Old Jun 16, 2009 | 10:03 PM
suff1cate's Avatar
suff1cate
What's the best way to check the timing? And the best way to fix it if it's not right? When I say I'm far from an expert, I mean far far away. I'm learning as I go. Thanks though!
Old Jun 16, 2009 | 10:07 PM
ctubutis's Avatar
ctubutis
No disrespect intended, but... Dude, you really need to buy a book....
Old Jun 16, 2009 | 10:09 PM
86bigred's Avatar
86bigred
you could have a bad cam as well.i have an old car that does the same thing and was told the cam is bad.just been to lazy to change it .
Old Jun 16, 2009 | 10:13 PM
suff1cate's Avatar
suff1cate
lol that's alright.. i have a book already and read about the timing but there's a big difference between reading a book and getting advice from an actual person. Unless, of course, the advice from a person is to buy a book. Why didn't I think of that already????
Old Jun 16, 2009 | 10:52 PM
bill11012's Avatar
bill11012
I just read the book, and the timing is set for life. You check it and if it is off, you change the ignition module. The book gives good instructions, better than i can give. do you have a timing light?You will need one.
Old Jun 17, 2009 | 07:42 AM
ctubutis's Avatar
ctubutis
Huh? Perhaps on computer-controlled, EFI engines this might be somewhat true
but it certainly doesn't apply to everything.
This brings up a good question, though - does this truck have a feedback carb or
not? My thoughts were no, it doesn't, but maybe I'm wrong. Nor do I have any
idea if the computer controls the timing on such engines....
Old Jun 17, 2009 | 09:49 AM
Franklin2's Avatar
Franklin2
It's backfiring because there is raw fuel inside the exhaust system. You will have to figure why that is happening. If the exhaust is black and smells like fuel, then I would suspect the carb. If it's not really running rich, I would suspect a timing problem or a valve train problem.
You are probably going to have to take to a garage with a old timer who can listen to the engine and tell you their best guess.
Old Jun 17, 2009 | 10:14 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You blew out the powervalve in your carb.
It's dumping fuel into the engine.
Old Jun 17, 2009 | 10:17 AM
bill11012's Avatar
bill11012
it is vacuum controlled by a module. It does not have efi or a computer.
Old Jun 17, 2009 | 10:36 AM
lew52's Avatar
lew52
An efi computer can change the advance but has nothing to do with the base timing... Lew
Old Jun 17, 2009 | 02:46 PM
Eddiec1564's Avatar
Eddiec1564
Franklin2 nailed it, its running rich. My 84 F250 300 I6 would do the same till I replaced the power valve in the carb.
Old Jun 17, 2009 | 03:17 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Does it pop on trailing throttle?
Is it SO rich it almost burns your eyes?
Really I'd hook a timing light to it to check, but I'd be willing to bet it's the powervalve.
Welcome to FTE suff1cate!
Old Jun 18, 2009 | 10:53 PM
FESuperDuty's Avatar
FESuperDuty
You sure you don't have some plug wires crossed? That can cause serious backfiring.
