Need help with A/c
Old Jun 16, 2009 | 03:49 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Need help with A/c
Hello every one,
On the 6.0 the A/C does not blow cold and there is no refrigerant in the line's. Took it to the Delar and they want $1,500 to replace to A/C lines and I was like get real. They say that they need to remove the engine to get to the lines
So my question is when I go under the truck I see 4 lines going all the way to the back and I was wondering if any one has part numbers for the lines,
Thanks
Nick
Old Jun 17, 2009 | 01:06 AM
Monsta's Avatar
Monsta
Sit. Stay.
Wait Nick....
Are you absolutely, positively sure that the lines are bad?
You need to locate the leak. Go to a independent mechanic and ask him to pressure test the system to locate the leak. Sometimes you can add a sealer to seal small leaks. Other times it there is something to be replaced.
Most of time the condenser gets a hole in it since it is right out front.
ncm0008
Jul 5, 2009 08:15 PM
weekendwarriorfsw32
Sep 11, 2008 11:21 PM
weekendwarriorfsw32
Jul 11, 2008 09:11 PM
oshoguno
Aug 21, 2005 10:04 PM
