Anyone Ever Change an Oil Pan Gasket Without Lifting the Engine?
Hey guys. Just wondering if anyone has changed an oil pan gasket (00 F350 SD, 4x4, 7.3L) with out lifting the engine or cutting the cross member? Or should I just drop the pan as much as I can, clean it the best I can and add RTV and bolt it back up?
Thanks for the reply. I didn't realize that you couldn't buy a gasket for these and now I see you have to use a special RTV from Ford or International.
Not really good to leave the engine in. After all, you have to clean out the RTV which is really hard to do. Next you have to turn the engine upside down so the oil doesn't ever touch the RTV while it cures. All hard to do while on the truck.
Like I said, I would never do it. Now sure how you would keep the sealing surface dry, that would be tough.
I imagine if you keep the pan off for a week, you might get away with it but why do that when it is easier to take the engine out as opposed to cutting and welding, hoping it all works out? And if not, what then? Cut and weld again?
I can attest to the fact they leak oil for days to weeks after you pull the pan...
And that is my question. How can you be sure it has stopped leaking when you put the sealant on? Also, if you are going to wait weeks for it, isn't it easier to take out the engine and turn it over? Not to say faster.
Thanks for the replies guys! I won't attampt to do it with the engine in then, no piont in trying something that won't fix the problem.
I'll clean everything agian and make 100% sure that is were the leak is. I know the front leak is either coming from the front main seal or the pan and the back leak is from the EBPV.
There's a few (more simple) things that could be leaking up front as well. Have you considered some fluorescent dye for the oil to help narrow it down? I'd hate to pull a motor for a bad gasket in the HPOP reservoir or something.
