Pulsating Lights
Old Jun 15, 2009 | 08:14 PM
429poweredf350's Avatar
429poweredf350
Pulsating Lights
My lights pulsate when the truck is running and the amp guage jumps as they do. Any ideas? Bad ground maybe????
Thanks,
Jerry
Old Jun 15, 2009 | 08:32 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Alternator or regulator.
Corroded cables can cause it too.
Is it pulsating at idle or going down the road as well?
Josh
Old Jun 15, 2009 | 09:06 PM
429poweredf350
Both at idle and going down the road. Cables are all new. truck just had a frame off resto.
Old Jun 15, 2009 | 09:08 PM
429poweredf350
Josh,
Alternator and regulator are new as well. I need to find a good wiring diagram. All the ones I've seen aren't all that good.
Old Jun 15, 2009 | 09:19 PM
Bullitt390's Avatar
Bullitt390
Isn't too far fetched these days to have a brand new part not work correctly.
What year is your truck? I have a couple diagrams I could post or link to.
Josh
Old Jun 15, 2009 | 09:48 PM
429poweredf350
Body and wiring are a 77. Thanks for your help.
Old Jun 15, 2009 | 10:17 PM
murph77's Avatar
murph77
I think you're going to find a ground somewhere to be the issue.
Since you just had a frame off restoration, I would bet money a ground is the culprit.
Check ALL of them. Make sure they were all replaced, and the grounding
surfaces didn't get coated with paint.
I went through this last fall. Pulsating lights.
In fact, when I saw your post, I thought someone had resurrected my old one.
Mine was easy though. Bad battery ground.
Murph.
Old Jun 16, 2009 | 08:15 AM
fmc400's Avatar
fmc400
MSEE
Sounds like a ground issue. The regulator grounds to the fenderwell, which is bolted to the firewall, which itself is grounded to the engine block through a braided ground strap. Without a ground strap, problems like this start happening. You can temporarily test this by running a ground wire from one of the regulator's mounting bolts to the engine block.
Old Jun 16, 2009 | 01:04 PM
429poweredf350
Thanks, I'll give it a shot.
Old Jun 16, 2009 | 10:19 PM
jurban's Avatar
jurban
one of my trucks did this, it was the ground for the bright switch on the floor.
jjc103
Jul 30, 2020 03:21 AM
Ftruck28
Modular V8 (4.6L, 5.4L)
Feb 15, 2015 05:20 PM
dahoserman
Feb 14, 2014 03:41 PM
mikulskn
Jun 26, 2013 11:23 PM
JoeBlow
17
Nov 4, 2005 04:33 PM
