Oil leak
Old Jun 15, 2009 | 06:26 PM
txaggiegolfer's Avatar
txaggiegolfer
Oil leak
I have an oil leak under the valley pan on the center of the motor. Part of the cover is rotted so I can see something moving while the motor is running. The oil is coming out around whatever is moving. What is this leaking oil and how to fix it?
Thanks
Old Jun 15, 2009 | 08:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What you see moving would be either the lifters or push rods.
What engine?
If it is a NA motor, replacing the valley pan would not be that hard.
IP removed, intake manifold removed and you would then be able to remove the valley pan.
Old Jun 15, 2009 | 09:00 PM
txaggiegolfer
It's a 87 6.9 not turbo'd. Where can I get a new pan?
Old Jun 15, 2009 | 09:25 PM
Dave Sponaugle
NAPA, Advance Auto, Ford, International and probably most other auto parts stores.
I would plan on a return line kit also since you will be disturbing the return lines when you do this job.
Intake Manifold Gasket Set - Advance Auto Parts
Looks like 62.99 plus tax at Advance Auto here locally for the valley pan.
Old Jun 16, 2009 | 01:07 AM
starmilt's Avatar
starmilt
Am I understanding the valley pan rusted out gees what does the rest of the truck look like, never seen this before, where are you located.
Old Jun 16, 2009 | 09:54 AM
txaggiegolfer
Truck has been in Texas since it was new. Has 142000 miles. I bought it from the original owner in November of last year. Got a new intake manifold gasket set at our local NAPA. In the installation it says that there is a tightening sequence for the bolts. What is this sequence?
Old Jun 16, 2009 | 09:17 PM
Dave Sponaugle
That has to be the intake manifold torque pattern.
Old Jun 16, 2009 | 11:22 PM
starmilt's Avatar
starmilt
I have to wander if someone washed it with something caustic and didn't get it all washed off at some time or other, never seen one rust out. I did see a toyota oil pan rust through one time though.
Old Jun 17, 2009 | 12:32 AM
David85's Avatar
David85
I thought the exposed part of the valley pan was some form of mild stainless steel? Never heard of one rusting out, thats for sure. Better change the oil while you're at it and inspect the top if the motor for any signs of debris or crud falling in there.
I don't suppose you could post a picture? That would be one for the collection.
Bryanblaylock
Oct 28, 2014 05:12 PM
rdunagan
Apr 3, 2011 01:32 PM
przao1157
May 1, 2009 04:18 PM
firefighter1416
1997 - 2003 F150
Feb 5, 2009 05:24 PM
95mazdab2300
1983 - 2012 Ranger & B-Series
Jan 7, 2004 05:21 PM
