instructions on how to rebuild a np 435?
Hi,
I have read here before that you can go to your public library and get this info. You can also find it in most late 60's to 80's Ford factory shop manuals. I unstand that common shop tools and a block of wood are all that required.
Good luck and let us know how it turns out.
Lee
Lee
The Haynes manual has an exploded view of the tranny. Maybe that'll help. X-fer cases are pretty simple. My NP 208 was easy to take apart and put back togeather....Sill waiting on those slow a$$ parts to come in......All I used was the exploded view.
For what its worth, before you tear into the tranny, take some of pictures of the innards so you have a reference on how everything goes together. Turn the input shaft, fool around with the syncros a lil bit, moving them back and forth to see which gears the tranny is in. This also gives you a reference on how everything should work once you put it all back together again. As you tear it apart, lay everything out on a bench or table as you take it out so you know exactly in which order everything came out. I am not an expert at rebuilding trannies, but this is the advice that everybody has given me, and it has worked for me.
Tony
Tony
Dustin_86
01-16-2019 02:57 PM
chukar
03-20-2017 03:34 PM
nathan328
10-14-2016 09:34 AM
1978crewcab
09-30-2016 09:18 PM
Wilber15
04-24-2002 08:48 PM
435, diagram, difficult, exploded, instructions, np, np435, photos, process, rebuild, rebuilding, street, transmission, truck, view
