RSS - Always solid tone
Old Jun 15, 2009 | 10:03 AM
Excursionator's Avatar
Excursionator
My Reverse Sensing System just started to give me a solid tone when in reverse. The cut-out switch on the dash still works correctly. I cleand the RSS sensors - did not fix problem. Does anyone know which fuse controls the system (2004 diesel) so I can check it? Any other suggestions?
Old Jun 15, 2009 | 11:12 AM
rlh68050's Avatar
rlh68050
That happens to me in the winter when a sensor ice's over. A good scan (Snap on, OTC) tool will run diagnostics on the RSS module.
Old Jun 15, 2009 | 04:06 PM
HeaVEEweight's Avatar
HeaVEEweight
I have the same issue. It goes "beeeeeeeeeeeeeeeep" when I go into reverse. Of course I hit the button to turn it off.
Old Jun 16, 2009 | 09:33 AM
rlh68050's Avatar
rlh68050
Either one of the sensors is bad, or it is the module itself. Like I said, you either need the Ford scan tool, IDS, or a good aftermarket one like Snap on Modis or a OTC Genisys to "talk" to the RSS module. The cheap Auto Zone type will not work.
Old Jun 17, 2009 | 06:22 AM
Excursionator
Thanks Rod, Found a cracked sensor. Replaced and now ready to back down the road. Appreciate your response.
JC
ski one
2009 - 2014 F150
Jun 8, 2010 11:23 PM
Skypilot1957
27
Jan 19, 2010 01:36 PM
lawlor
Dec 18, 2007 05:28 PM
dan911
Jan 24, 2006 07:41 PM
